0 Members and 2 Guests are viewing this topic. Read 145525 times.
I need to get the Vault to unlock again as it were. Should the necessary trouble shooting required exceed what can be done remotely via phone or e-mail... well, I then may draft my Olive Symphony into service
My NWO 3.0-GO's digital input allows me to compare the Transporter receiving streamed data vs the VRDS- NEO spinner's data using the same converter.
Thanks to all who have contributed here and for those who understand that sometimes things DO get damaged in shipping. The important thing is that Customer Service and Satisfaction are KEY in ModWright's approach to business.Thanks and take care,Dan W.
I rechecked the digital volume issue on the slim forum.It does appear you can be down -36db w/o going below 16 bits. Actually you can be -42 but one should assume 22 bit rather than 24 bit to account for 2 bits being lost to thermionic noise? or something like that.-36 is a lot to play with. I took off my endler balanced att's and I think it sounds better.SNR is a theoretical issue since digital att doesn't decrease noise but in practice it is not an issue in my system.The snr is so good in TP that it shouldn't be an issue.
The ideal comparison, however, will be the Esoteric as player vs. the Transporter as DAC via Computer server - connected via ethernet connection. It is the computer interface that truly makes the Transporter shine.Dan W.
Quote from: tomjtx on 3 Mar 2008, 04:40 pmI rechecked the digital volume issue on the slim forum.It does appear you can be down -36db w/o going below 16 bits. Actually you can be -42 but one should assume 22 bit rather than 24 bit to account for 2 bits being lost to thermionic noise? or something like that.-36 is a lot to play with. I took off my endler balanced att's and I think it sounds better.SNR is a theoretical issue since digital att doesn't decrease noise but in practice it is not an issue in my system.The snr is so good in TP that it shouldn't be an issue.Tom, Interesting finding on the Endler attenuators - better sound with off than on.Thanks for the report,Bill
