0 Members and 1 Guest are viewing this topic. Read 42406 times.
Thanks, Lar. I might try some 'conditioning' as I am still experimenting with the VPI HW-19 and I should have an old DUAL Idler Drive coming (thanks to HurdyGurdyDave)...both of which are AC motors and would certainly seem to benefit from some mains conditioning.
I might go mad before this analysis is over..... Wayner
I assume you are using the 8.468" stylus to pivot distance as the spacing from turntable spindle to tonearm pivot didn't change? Or, what spacing are you using, me wonders? My logic tells me that the spacing from the original SL-1200 tonearm should be used.Wayner
John,Do you use a VOM to dial in the exact voltage, or just trust the front panel controls?Wayner
