0 Members and 1 Guest are viewing this topic. Read 158145 times.
As I mentioned... even if I find operating points for the 6H30... I would have absolutely no clue how to use the data to determine what parts would need to be changed for whatever values.JD
We can help you work out the necessary changes if you will do the leg work to obtain the necc. data.
Quote from: jeffdavison on 24 Mar 2008, 04:57 pmAs I mentioned... even if I find operating points for the 6H30... I would have absolutely no clue how to use the data to determine what parts would need to be changed for whatever values.JDBut that is what I said I would help you out with. I quote myselfQuoteWe can help you work out the necessary changes if you will do the leg work to obtain the necc. data.
I'm sure you're right. The 5687 should be able to drive the KT88 with aplomb. But you say you are using a pair to drive a pair. Do you mean PP, PSE or just the stereo channels? Also, since the 5687 has dual triodes are you parralleling the sections?
Anyone else make any headway on theirs?
Found my answer to the aluminum/copper mix... in leyman's terms its bad.one commentary on mixing metalsI am not sure I will have an electrolyte present, but still its better to not risk it.
