0 Members and 1 Guest are viewing this topic. Read 158146 times.
comment on whether it would be better to use 30 uF or 47 uF for the rectifier cap
I ordered a new choke, one that could handle a great deal more current than the 5H/200mA one. This is because I am planning to build Pete Millet's E-linear amp first (with the 6550 of course). This topology has really got me interested. It also is the most demanding in terms of power supply due to the gas regulators pulling an extra 30mA per channel. This will give me the room to go in many directions if I wish.I ordered up all the parts for the e-linear amp, except for a couple resistors that digikey didn't stock, like a 82K metal oxide 10+watt resistor. I think I figured out a nice way to prototype the amp, making it semi permanent but also flexible enough to try out other things too. I'll do this by subdividing the top plate into sections. That way I can sub in another front section without rebuilding a whole new plate. I've seen this done in a few other diy amps and I have a bunch of aluminum sheets to work with.
Josh,Sorry, didn't mean to imply anything by my responnse.
Tell me more about this PSE 6550 amp -- how many output tubes per chanel, how much power, what kind of ps voltages?I ask because I know somewhere down the line I want to look into a big PSE valve amp for the Sapphires. The PUBM -- Penultimate Uber Beam Machine (M7 Series if you will, and to keep things "on topic" :: )
