Trying out Vinyl
0 Members and 1 Guest are viewing this topic. Read 18701 times.
wilsynet
Re: Trying out Vinyl
« Reply #60 on: 26 Feb 2009, 06:54 am »
What cartridge have you been using with it thus far?  I cannot remember if it came with one when you bought it or you had fitted one of your own to it.
It came with the JVC MC-200E, the original cartridge model that shipped with the turntable when it was new.  I think it is quite a noisy cartridge, and I hear what I think is an excessive amount of pops and clicks despite repeated and thorough cleanings of the records.  Maybe that's the records, but I am suspicious that it isn't.  Once I hear the same records on a different cart, I imagine I'll be able to draw some better conclusions then.
avhed
« Reply #61 on: 23 Jan 2010, 04:43 am »
I had a Music Hall MMF-5 as my starter table. I did a head-to-head shootout against a Rega P-25 w/ a Rega RB-900 arm in my home with my system. The Rega was not significantly better (not that you are considering a P-25, but just as an FYI). IMHO, there isn't really a significant "step up" until you are ready to drop $3k. I'm on my 2nd Teres table.
I find this hard to believe, unless what is significantly better to me is not significant to you.
I wonder what is your associated eqiupment. Does your system have enough resolution for the Rega?
AudioSoul
« Reply #62 on: 23 Jan 2010, 05:04 pm »
   I suggest that you dont buy a new british TT. If you spend $500. is like getting a $300. TT. With the import duties and
   such. If you buy a used one in the US the duties have already been payed for....... 8)
ricmon
« Reply #63 on: 25 Jan 2010, 09:22 pm »
You said duty  :lol: :lol: :lol:
