Nathan wrote:
People get so paranoid about having controls. Adjustability is a GOOD thing. One pot, if it allows you to tweak the sound the way you want, is a good thing. The real trade off is having NO parameters to adjust whatsoever. That's why tone controls are stigmatized, cause of this paranoia about a single piece of electronics in the chain.
Actually, "anal" might be a better adjective than "paranoid".
Nathan, where should we draw the line between paranoia and concern?
How many user adjustments and additives can you have before it has any negative audible effect? Adjustments on the amp, preamp, cd player, speakers?
Let me ask you this? With a 3 way speaker, which is better: 3 potentiometers controlling the level of each driver, or a 3 way electronic crossover with no passive crossover devices? If you believe one is better than the other, then I suggest that you may be a little paranoid because you think that you could hear a difference.
Taking it a step further, is it possible that a lot of folks think that both alternatives affect the final result, and that it may either be beneficial or detrimental?
Of course, if you can't hear any difference, then you are correct in your representation of the views of those who share your perspective.
Same goes for the recording process. Look at how many ways recording "engineers" can now "adjust" and "shape" the sound to their liking. I'm sure they think they are making it better. But, what someone think sounds good is a personal bias.
