0 Members and 1 Guest are viewing this topic. Read 8291 times.
My son just picked up a new Tele Squire last Wed. for $99.00. It's a nice unit, easy to play and sounds good. He already had an amp. So if the balance of the equipment is worth $150. to you it may be a good deal but I bet you could find a decent practice amp for less than that. BTW, he bought the Tele at a small chain that I believe has stores in the Chicago area, Music go Round.
Could anyone here give me some advice on buying a "budget" electric guitar and amp for an adult first time player to start with? Could we get in under $300 either new or used? Any other tips much appreciated!
OK, I'm nixing the Squier package and will aim for a higher quality used Fender or the like.Any suggestions on self-instruction? Books? Video? I'm open to either.
This may sound crazy, but I found lessons, when I first started to be a waste of time for me and the instructor. I'm mean if you sit there and and can't do anything, why bother? So by using books, and online tabs and such, I just kept working on those chord shapes, etc until I could make reasonable sounds. One problem w/ this is I tended to just noodle around and not really learn songs, which leads to timing/rhythm issues. My buddy, the hotshot player told me I needed to play along w/ recordings. But the problem w/ that, is in the beginning, most recordings are way too fast. I bought some software for $50 that allows one to slow down the music, but maintain pitch. Since I started using this, my playing has gotten dramatically better.I also started out more like a teenager would....that is by playing power and barre chords , rather than the more traditional approach of learning open chords and playing folkie type songs. Until recently, I could play a much better version of "Blvd of Broken Dreams" than "House of the Rising Sun" I do benefit from getting the equivilent of lessons by playing w/ my pro musician friends. I might go and start actual lessons at some point in the future.Regarding neck shape, curved radius necks maybe easier for rhythm playing, where as flatter necks for lead. But, that just personl preference.I realize that recommending say, Fender over Squire drives up the price, but my point was, if you get something good, you'll never loose money on it. And, once again Jman is correct. Pre 2006 MIM Fenders are a dicey issue. I would never buy one without have a pro check it out first.Hey Jman....I recently got an Epi Valve Std. (I thought I was bidding on the Blues 30) I like it ok, but the bass tone control was designed incorrectly or has the wrong value components, because its either off or on. Is this part of the modification you were refering to?
