0 Members and 1 Guest are viewing this topic. Read 5478 times.
I'm thinking about getting a dedicated circuit for the amp/pre and audio gear as soon as possible, however that won't be for a while. Does anyone know what could be causing this problem? Everything sounds better and quieter than ever, but I dont' want to damage my system. Any suggestions?
Make some DIY "audiophile" extension cords. I was forced to do this when i moved my system to be firing into the length of the room, which was not how i designed the room when we were building the house (im no sound specialist back then) so in order to use my dedicated 20 amp line i had to make two 15 foot extension cords. Just went to home depot and got some good big cable and some decent connectors and viola. Better then spending a fourtune on some junk that does the same thing just as good. and alot cheaper then moving the plugs to that area. You could even do an outlet box using hospital grade plugs and all.
I would use an extension cord with a Highwire Wirewrap tuning device attached and feed off another outlet, preferably cryo'ed. Also, leave your equipment on 24/7. Don't believe everything Van Alstine says. Setting up your system along the long wall improves sound by delaying primary reflections. That's why imaging is so much better. Difussors placed on the rear wall in between the speakers will also improve soundstage depth. I have used RPG Pro Foam panels with success. Rhynos's DIY two dimensional diffuser should work even better.
That problem is in the low quality switches of your fan and lights rather than any inherent fault of your hi-fi equipment. Fixing the popping at the source is much more effective than spending big further down the line.
when I turn on my amp or preamp a large "thump" or surge of power comes through my speakers
Thanks for the suggestions. I'm going to try a more simple approach and if it doesn't work, move on to more expensive and sophisticated solutions. This isn't an issue of leaving things on or off. My gear has tubes and I don't like leaving tubes on all the time. Plus, on my other outlet (only a few feet away from this one) I never experienced this problem. It's not a question of one outlet being cryo'd or not having been properly lubed (with snake oil), it appears to be associated with the switch. Not ...
Seriously, that popping is junk in the mains lines. While at it, why don't you hit the nail on the head and get a decent line filter? It will both get rid of the annoying and potentially dangerous noise and act as a distribution box with prolonged power cables.Anyway, think about it.Cheers,DVV
Jack, that popping is no voodoo, nor is it from that sixpack of beer you hogged the night before. Seriously, that popping is junk in the mains lines. While at it, why don't you hit the nail on the head and get a decent line filter? It will both get rid of the annoying and potentially dangerous noise and act as a distribution box with prolonged power cables. Anyway, think about it. Cheers, DVV
I appreciate the feedback and got a real chuckle out of your beer comment. My wife would also agree!Jack
Van Alstine does not believe in noise filtration--says that his gear is good enough. The same goes for (audio grade) power cords, interconnects & speaker wire. It's quite a limited perspective, I'd say...
