Does anybody make a toslink Y adapter?
0 Members and 1 Guest are viewing this topic. Read 2606 times.
warnerwh
« on: 6 Sep 2003, 06:32 am »
I could use a toslink Y adapter as I don't have a coax out.  Anybody know of one? Thanks
Rocket
toslink y adapter
« Reply #1 on: 6 Sep 2003, 11:08 am »
hi warner,
can you tell me what a toslink y adapter is?
my pioneer pds 507 doesn't have a digital coaxial out either.
regards
rocket
bob82274
« Reply #2 on: 6 Sep 2003, 03:03 pm »
By Y-adapter I assume you mean one that has two input/outputs going to one output/input, correct?  If so I believe I saw one at Radio Shack...
warnerwh
« Reply #3 on: 6 Sep 2003, 03:16 pm »
Bob is correct, 2 connectors on one end and 1 on the other.  I'll check out Radio Shack, thanks
lcrim
« Reply #4 on: 6 Sep 2003, 08:27 pm »
Been on vacation, catching up.  Try out this link, I have bought from this site in the past w/o problem.
http://www.soundprofessionals.com/cgi-bin/gold/category.cgi?category=220&item=SP-TOC-SPLIT&type=store
Rob Babcock
« Reply #5 on: 8 Sep 2003, 05:21 pm »
You can get one from http://www.partsexpress.com as well.
warnerwh
« Reply #6 on: 8 Sep 2003, 09:40 pm »
Thanks for the help. Is there any reason these would cause any losso of accuracy?
lcrim
« Reply #7 on: 9 Sep 2003, 01:40 pm »
Warnerhh wrote:Thanks for the help. Is there any reason these would cause any losso of accuracy?
Because it is not just 0's and 1's, I believe you have a valid concern.  Jitter and timing are just 2 components in a digital connection that will be affected to a certain extent  by the  Y connector.  But for $20 and shipping costs, try it out and judge for yourself.
BTW, why do you need 2 optical outs from one connector?  You will also need 3 optical cables which will raise the cost over $20.  For glass optical cable at a reasonable price and superb quality try this link: http://mcm.newark.com/NewarkWebCommerce/mcm/en_US/support/catalog/productDetail.jsp?id=24-6485
vettemanbc
2 into 1, NOT 1 into 2
« Reply #8 on: 25 Sep 2003, 12:22 pm »
I have the radio shack optical "Y", but it is only good for splitting one into two. It will not/does not work for two sorces into one input. I don't know why not, and only found out after I bought the thing, thinking it would!
bigwally
Re: 2 into 1, NOT 1 into 2
« Reply #9 on: 26 Sep 2003, 05:09 am »
Quote from: vettemanbc
I use the Rat Shack Toslink adaptor to run two CD players into one P-Tech DAC. You have to turn one player off for the other to play, but it works very well for me.
