Can you join L/R outputs of preamp safely
0 Members and 1 Guest are viewing this topic. Read 659 times.
warnerwh
« on: 4 Oct 2007, 04:43 am »
Just like the title says. I'd like to combine Left and Right channel outputs from my preamp to one input on an amplifier. Is there any issue here? Thanks in Advance!
JohnR
Re: Can you join L/R outputs of preamp safely
« Reply #1 on: 4 Oct 2007, 08:51 am »
Depends on the preamp but it's most likely not a good idea. You would want at a minimum a resistor on each output (say 10k).
warnerwh
« Reply #2 on: 5 Oct 2007, 04:10 am »
Thanks for your help. Fortunately it dawned on me I can do this with my Behringer crossover.
