seeking solid copper wire source
0 Members and 1 Guest are viewing this topic. Read 1351 times.
SwedeSound
« on: 26 Sep 2007, 04:32 am »
Hey... I am intrigued by the "anticables" speaker I've read about in various forums and realized I could try and make them myself (one of a handful of DIY audio projects I feel up to), but I'm having trouble finding the exact kind/size of bulk cable. Near as I can tell, the anticables are a 12 AWG (oxygen-free, highly annealed, enameled, etc?) solid core copper wire, aka magnet wire.
I have seen some listings on Amazon or eBay (close, but not quite what I'm looking for), and also checked a few local hardware stores, where it seems more like stiff, automotive and/or hookup wire. There are some commercial sites that seem to offer it, but they often require very LARGE orders and their order forms are pretty cryptic. Any help and suppliers you can suggest would be greatly appreciated. Oh, and I'm bi-wiring, so I am looking for 8 lengths of 8-10 feet, so between 64 and 80 feet of wire...
Best,
Jason
DaveC113
  • ZenWaveAudio.com
Re: seeking solid copper wire source
« Reply #1 on: 26 Sep 2007, 04:36 am »
He sells bulk for $1.25 / ft... just call him and you'll have it in a few days. Magnet wire comes in lots of different types of copper and insulation, so what you're ordering may or may not sound as good as the real thing.
Sonny
« Reply #2 on: 26 Sep 2007, 05:10 am »
Hi there, I have been making DIY i/c and speaker cables for a few years now..
If you're talking about Speaker cables, go with 11 gauge for bass and 14 for mid/tweeter
and for i/c I would not go larger than 20 gauge...
I use Magnet wire with much success.
Tuan
Get them at planetengineers.com
Wayner
« Reply #3 on: 26 Sep 2007, 11:33 am »
Go to a motor rewinder guy in your area. The cost will be about 10 cents a foot.
Wayner
