0 Members and 1 Guest are viewing this topic. Read 6427 times.
Remember here that in my case, I did not change the wireless connection to the Transporter. I changed the wireless connection to a wired connection on the *computer* that is running Slimserver.
I'd recently done the same and also heard a change in the sound. I can't say if it's better, but it's different. I'm going to switch back to wireless in a day or two and try to get a sense of which I prefer. Slimdevices recommends a wired connection:"Wired or Wireless?Ideally your SlimServer should be wired to your router.If your SlimServer PC is wirelessly connected to your router, all its traffic will go over two wireless hops: the SlimServer to the router and the router to the Squeezebox. This restricts bandwidth and may cause dropouts in radio-adverse environments with high-bandwidth lossless music formats.This is not to say it won't work as more than a few SlimServer users do it this way, but caution is advised."I don't know if the restricted bandwith can affect the sound but something sure changes between the two connection types.Quote from: PhilNYC on 25 Sep 2007, 10:07 pmRemember here that in my case, I did not change the wireless connection to the Transporter. I changed the wireless connection to a wired connection on the *computer* that is running Slimserver.
The quoted text seems to me to be in reference to 'classic' network bandwidth issues vs. sound quality. I've not noticed any dropouts, at least by my definition (a pause in or temporary stoppage of music). Regardless, I'm looking forward to your update. At this point, I can use all the 'new computer' justification fodder I can get!
Phil, are you also connecting your Transporter with a wired ethernet or are you using wi-fi? I understand that that the computer running Slimserver is now wired to the network. So we are talking about two network connections here, right?--(1) the computer runnning slimserver wired to the router, and (2) the Transporter or SB. I wonder if you are finding that (1) is more important than (2) for reducing jitter and improving sound via a wired connection. I am still hoping to go with a wireless SB2 setup, but with a wired Mac Mini / Slimserver with apple lossless..Thanks for sharing these findings.Rob
