0 Members and 1 Guest are viewing this topic. Read 21510 times.
A decent extended range driver shouldn't really need a supertweeter. The "dangers" of adding one could include:
1. Producing a "tipped up" sound as most single driver speakers are somewhat bass weak already.
Losing the purist single driver advantages (point source coherency, active design dynamics).
3. Adding the evil power robbing/phase shifting crossover.
Sure Doug,I will take you up on borrowing the ribbon super tweeters. I assume it comes with a high pass filter?TCG, That's some serious super tweeter. I would like to hear it some time if I get a chance. I will try douggie's unit to see if I like the sound with supertweeter first. I think Dmason had something cooked up for the superhemps on another thread. It may have been in that darkstar thread. I will have to do some searching when I get some time.
Great informations. I have the 1st generation superhemps. What caps are people using for 1st order highpass? Anyone figured out the roll off point on the hemp drivers?
I am using ICW Clarity caps, bought from DIY cable. I picked a value of 2.2uF, and this gives a cutoff frequency of 1/2/pi/R/C = 9.04kHz. The tweeter is a nominal 8 ohm impedance.
Quote from: ashok on 12 Sep 2007, 02:34 amI am using ICW Clarity caps, bought from DIY cable. I picked a value of 2.2uF, and this gives a cutoff frequency of 1/2/pi/R/C = 9.04kHz. The tweeter is a nominal 8 ohm impedance.So I'd suggest playing around with the crossover cap before making your mind up. Too big a cap and you might get more overlap than you want leading to a frequency bump in the 5-10khz range. Too small a cap and you won't get much benefit. Find the right value and it will sound just right.
I agree with you. As I did say in my previous post, try different capacitor values till you find one that you like the best. The 2.2uF sounds good in my setup, and I went with it.
