0 Members and 1 Guest are viewing this topic. Read 8620 times.
How hard were you driving the amps? If the volume was too high, maybe the tube amp ran out of "gas" while the big Adcom was still coasting.
Ran into an interesting thing today while i was doing some room correction / frequency analysis tests.... I was wondering if anyone might be able to shed some expert advice on this?
If you want to mate speakers to your SET amps, you need higher sensitivity and flat impedance.
I think you will see now why SET lovers choose many single driver speakers and other eccentric designs.
Steve, I agree with your points...just saying that those are the goals.
I think many SET lovers deal with the tubby bass from the driver's resonance or xo the driver they are running to avoid it.
In my setup those two amps sounded very different, especially with female vocals.
Actually, I was just going to ask you Adam, if you did any back to back listening between the 2 amps?
Doing a quick search of speakers commonly used with tube amps reveals interesting information. Many impedance curves look like profile shots of tsunamis! What kind of crazy non-flat responses are many people experiencing? enjoying? Clearly, a ruler flat graph isn't the only valid pursuit but if you are searching for an accurate and uncoloured reproduction, it is an important consideration.
I really hate to bring this up because it will likely cause this thread to spiral out of control but....frequency response based on an anechoic measurements doesn't reveal the entire story about how a speaker truly sounds. When you look at a Lowther PM2A (my favorite driver) from 200Hz and up the FR graph looks like the Swiss alps. When you listen to it in your (or at least my) system you encounter a completely different world. There is less coloration with this driver than with nearly any other driver or speaker I've played with. Don't ask me why because I can't explain it. Maybe its room interaction, maybe its the reactive nature to the SET amps I use, maybe its my placement of the driver on its OB,....
... You have to remember that tube amps do a great job of providing voltage but when it comes to current delivery, often times they fall short. ...
