0 Members and 1 Guest are viewing this topic. Read 8671 times.
I think it's fine to have a double standard. I like the tubes in the living room, they're friendly to the material. When you sit down and really listen hard though, you can tell that they put a sexy evening dress and some smoky make-up on whatever you're playing.
So if tube amps suffer from high output impedance and if one has multiple impedance taps, what's the downside to just using the lowest impedance tap? Like using the 2-ohm tap on an 8 ohm speaker?
Quote from: mfsoa on 9 Sep 2007, 03:27 pmSo if tube amps suffer from high output impedance and if one has multiple impedance taps, what's the downside to just using the lowest impedance tap? Like using the 2-ohm tap on an 8 ohm speaker?Well, generally speaking, the output tube would see an increased plate load which can result in increased distortion. First, transformers reflect impedances by the square of the turns ratio. Second, a given tube ideally wants to work into a given plate load for best performance. In a typical series feed SET amp, the output transformer's primary serves as the plate load for the output tube. The top of the primary connects to B+ and the bottom of the primary connects to the tube's plate. The ideal plate load for the output tube is much higher than the loudspeaker's nominal impedance so output transformers are essentially step-down transformers.Let's say the tube needs to see a plate load of 5,000 ohms. If the loudspeaker's nominal impedance is 8 ohms, then you need a turns ratio of sqrt(5,000/8) or 25:1. And that's all the various output taps are on an output transformer; different turns ratios which will give the same primary impedance for 16, 8, 4, and 2 ohm loudspeaker loads.So for the same 5,000 ohm primary impedance, the turns ratio for the 2 ohm tap will be sqrt(5,000/2) or 50:1. Connect an 8 ohm load to the 2 ohm tap and that 8 ohms gets reflected back to the primary by the square of the turns ratio, which in this case will be a factor of 2,500. So with an 8 ohm load on the 2 ohm tap, instead of seeing a plate load of 5,000 ohms, the output tube sees a plate load of 2,500 x 8 or 20,000 ohms. Four times higher than it should be.se
Who said a tube needs to see a given reflected back impedance... some ancient GE Tube Manual written in 1962 ?
Why not setting the design operating point to the minimum distortion as a valid operating point ?
frequency response based on an anechoic measurements doesn't reveal the entire story about how a speaker truly sounds.
Have you tried running the Adcom with a 2 or 3 ohms series resistor between the amp and the speakers?
Quote from: slbender on 9 Sep 2007, 05:37 pmWhy not setting the design operating point to the minimum distortion as a valid operating point ?Unless I'm missing something, isn't this pretty much how most folks go about doing it?se
