Vishay bulk metal-foil resistors sound
0 Members and 1 Guest are viewing this topic. Read 3060 times.
Levi
« on: 15 Aug 2007, 03:11 am »
Hi all,
Does anyone know what type of improvement from simply changing to Vishay bulk-metal foil resistors?
Example:
"Vishay bulk-metal foil resistors replace the already high quality Caddock resistors in the plate-loading circuit."
"Vishay bulk metal-foil resistors also replace the standard metal film resistors as the shunt element in the volume control circuit. "
Do you hear the difference between Vishay vs Caddock?
Levi
SET Man
Re: Vishay bulk metal-foil resistors sound
« Reply #1 on: 15 Aug 2007, 03:36 am »
Hi all,
Levi
Hey!
   Well, I've never use Vishay. So , I've no idea what they are better than Caddock :? But they are sure cost a lot more than the Caddock.
   For example... Caddock MK132 1K cost $3.95 each and Vishay S102 1K cost $11.50 each. :D
   BTW... I do have Caddock (MK132) resistors in my pre and my SET monoblocs and no complaint here. :D
   I do need to increase the step of my attenuators. I might try the Vishay this time to replace the Caddock (TF020) but at different value. But even with different value I think this should tell me which one is better. :wink:
Take care,
Buddy :thumb:
