0 Members and 1 Guest are viewing this topic. Read 13014 times.
Is it true diffusors are of no real benefit unless they are 6' or more behind the listening position? I tilt my chair back and I'm only 6 inches from the rear wall, so I use Aurelex absorbers. I own many diffusers and might try some on the ceiling rear of the first reflection point absorber panels.
Is it true diffusers are of no real benefit unless they are 6' or more behind the listening position? I tilt my chair back and I'm only 6 inches from the rear wall, so I use Aurelex absorbers. I own many diffusers and might try some on the ceiling rear of the first reflection point absorber panels.
Are your ribbons on the inside or outside?Inside images MUCH better.Perhaps if the ribbons are outside you're running off the difusors as it pan over? My skylines are not directly behind, but rather centered on the ribbon to catch as much of it as possible (doesn't do much for the bass so no real loss there).
Ideally diffusers should be 6' or more from the listener. At a distance of 4-6 feet there is some compromise - definite, but not disastrous. It depends on the type of diffuser and the location (sidewall, ceiling, backwall) and personal preference. At 6 inches, your head may be IN a diffuser well - not good. Jason
Do certain diffusors perform better for certain size rooms? I contacted RPG a while ago, and they recommend their QRD734 for large rooms, the Skyline for medium-sized rooms, and the BAD panels (which rely on a crazy array of absorption/reflection dots) for smaller spaces. Of course, they didn't give exact dimensions for each... doh!-- Nils
* A diffusor does no good unless sound strikes it. This is one reason the rear wall behind you is useful for diffusion - that's where your speakers are pointing. If you put diffusors on the side walls or ceiling but away from reflection points, they won't do much useful because what little sound reaches them is after bouncing around the rest of the room first.--Ethan
Also, if you want to try the diffusion up front behind the Maggies, orient them do diffuse vertically instead of horizontally.Bryan
Sorry, guess I was kind of unclear. You would still mount them on the wall but turn them 90 degrees so that the 'ribs' are running side to side instead of vertically. This will keep the horizontal imaging tighter but increase the vertical size.Bryan
I'd definitely try the diffusion on the rear wall and on the rear half of the side walls. Kill the corners with the Tri Traps. Try the 244's on the front wall but between the Maggies, not behind them.
