Shopping for a preamp
0 Members and 1 Guest are viewing this topic. Read 1762 times.
Curt
« on: 26 Aug 2003, 07:57 am »
You might want to look at the IRD Purist preamp. It's SS, extremely quiet, transparent, and it has a liquid mids and highs no SS harshness.
It is gain selectable (0-> +9.5dB), at 0dB it is effectively a buffered passive.
It has dual outputs for bi-amping and is inside your cost range. Some guys on AC have this model and may offer their opinions.
Black is the standard faceplate now. You can read more here
http://www.ird-thailand.com/products/purist/purist.htm
Mad DOg
the above post was moved from the 2 channel circle...
« Reply #1 on: 26 Aug 2003, 08:55 am »
in reply to the post below...
Quote from: beat
Hello all,
I think I need to pick up a preamp..I mostly need it to only switch from TT to CD and to allow for bi-amping. Any suggestions for under 1000? If there is some alternative to running a preamp that someone knows of I'd be into that as an option (to eliminate as much circuitry as possible). Im running tubes for the top end an SS on the bottom end.
thanks in advance, beat
Curt
« Reply #2 on: 26 Aug 2003, 09:52 am »
Sorry guys, guess I can't post IRD product info in some of the areas. I believe the rules may have been updated? I'll go read the mfg posting rules so I understand current AC policy.
Thanks, Mad Dog, for moving my post into a correct area  :oops:
