the best preamp for the amplifiers nuforce
0 Members and 1 Guest are viewing this topic. Read 12333 times.
samuel33
« on: 28 Jul 2007, 09:47 pm »
What is the best association you have heard with the nuforce?
Have someone tried the Nagra PL-L ?
Midnite Mick
Re: the best preamp for the amplifiers nuforce
« Reply #1 on: 28 Jul 2007, 10:24 pm »
If you like the Nuforce sound (speed and dynamics) then their own preamps would be best suited for them.  If you are looking for some more emotion then I would recommend a tube pre.
JayDoubleU
« Reply #2 on: 28 Jul 2007, 11:46 pm »
P8 is very good with NuForce amps. I have Ref 9 SE connected, planning to upgrade to V2 and P9 though. I agree with the previous statement about emotion and tubes. That is why I  have a Musical Fidelity X10V3 tube buffer between my Rega Saturn and P8. It just provides that little bit of extra that the pure sound lacks. Of course, using these 'tweaks' is very personal, depending on one's own taste
samuel33
« Reply #3 on: 29 Jul 2007, 12:36 pm »
Someone has told me that there some electricals compatibility to think about when you want to make a good match between nuforce and a preamp : what are they?
beachbum
  • Vinyl Delivers all of the Music
« Reply #4 on: 29 Jul 2007, 01:32 pm »
i replied to your post on audiogon on this samuel33 dont know what your friends problem with nuforce preamps was.  here is a little more info of my experience.  i used a p-8 with my ref 9s a few years ago that was a fine combo, i then upgraded my ref 9s to se last year and used p-8 with them.  i wondered what a tubed pre would do for my system and bought a marsh p2000t tubed preamp, i also did some tube rolling and i liked the marsh better than the p-8. taking in account that both are mid priced preamps i enjoyed the tubed sound better than  p-8. then nuforce came out with p-9 and offered a sweet full retail offer to trade p-8 to p-9, i went for it and glad i did, p-9 is in a different class than both p-8 and marsh. a great match for my ref 9 se amps. i think nuforce is offering a in home audition for a dollar. sounds like a good time for a audition. i have read here that p-9 may have matching problems with speakers that are easy to drive due to the steps in the volume control, though nuforce my have addressed that mismatch, good luck on your choice,
samuel33
« Reply #5 on: 29 Jul 2007, 07:25 pm »
I don't want the P9 or the P8 (just question of personal taste....)
Nobody had listen it with a nagra ?
giannettino
« Reply #6 on: 29 Jul 2007, 08:39 pm »
have you listened the 9Se V2 + p9 combo? is my actual setup and sound GREAT..i've tried with ARC pre, Tact Pre , Accuphase pre and some DIY.....IMHO the P9 is very big deal for the price..
My two cents..
Gianni
P.S.: i apologize for my poor english
rustydoglim
    • www.nuprimeaudio.com
« Reply #7 on: 29 Jul 2007, 10:11 pm »
P-9's gain can be reduced by 50% for high-efficiency speaker.
radisic
« Reply #8 on: 30 Jul 2007, 03:00 pm »
I have very very good experience with passive TVC (transformer volume control) preamps connected to my Ref 9s. I personally use Promitheus TVC, which is an audio bargain with fantastic sound qualities. If you want something more expensive and up-class, like Bent or Music First.
radisic
« Reply #9 on: 30 Jul 2007, 03:02 pm »
I ommited the verb from the last sentence  :oops:, but I'm sure you got it :wink:
mcgruder
« Reply #10 on: 7 Aug 2007, 10:56 pm »
Sorry, no experience with Nagra.  I really like the way the BAT VK-31SE synergizes with the Nuforce 9SE's.
rustydoglim
« Reply #11 on: 10 Aug 2007, 04:22 am »
samuel33
« Reply #12 on: 7 Sep 2007, 02:32 am »
I have just heard the best preamp of all that i have experienced before : the shindo Vosne Romanee.
I have compared it face to face with the VTL 7.5 : the Vtl isn't even close!
I haven't heard with nuforce amp -too bad i know- but since there are great feedback from whose have used nuforce with tube preamp (moodwright for eg.) i'm quite sure that it can be a terrific combo
referenceaudionz
« Reply #13 on: 8 Sep 2007, 10:55 pm »
Shindo Aurieges is an amazing bargain & makes the half dozen top-end passives I've had sound broken on Ref9SE
denjo
« Reply #14 on: 9 Sep 2007, 02:20 am »
From my limited experience, passives need a very powerful amplifier to realise their full potential! It also depends on what passive preamp you are using! I have used a Bent Audio TAP with digital amplifiers (CIAudio D*200s) and while they did sound quite good, the potential unleashed only came when I matched the passive with a much more powerful amplifier. Before that, the usual expressions that passives sounded thin, bass-shy and dry were true but after I replaced the amplification, I have had no issues with any of these criticisms. I have also tried tube preamps (but not the Shindos) but these did not work out for me.
Midnite Mick
« Reply #15 on: 9 Sep 2007, 03:07 am »
Maybe I shouldn't give my opinion given that I have not heard the passives that you are talking about but I don't think that they would work well with the Nuforces.  I think you need a tube preamp that is going to add some body and emotion to the sound.  You would lose a little speed but it comes down to personal preferences I guess.  I mean if you are going to go the passive route you might as well go with the P8.
Just my .02
Good luck,
Mike
arthurs
« Reply #16 on: 9 Sep 2007, 03:30 am »
I heard the NuForce (can't be positive if it was 9's or not) with Dan Wright's new pre at a friends house and it sounded pretty darn good, best I've ever heard NuForce sound.
Christopher_D
« Reply #17 on: 28 Oct 2007, 11:02 am »
Another choice : preamp Ayre K5XE ... I have been told it is a wonderfull match with Ref 9SE, even better than P9.
timothyharnett
« Reply #18 on: 31 Oct 2007, 01:49 pm »
I'm now using a Promitheus balanced in to 9v2 SE.  I've found it better with a Cambridge 840c than using a the 840c as a drive in to Tag Mclaren AV32r BP192 as a DAC/Preamp and then in to Nuforce.  Much cheaper too.
Albireo
« Reply #19 on: 1 Nov 2007, 01:18 am »
For something different, consider a Bel Canto DAC3 as DAC + preamp, feeding directly a NuForce amp. This is what I have, and no one would accuse the combo of being anything less than top-flight in terms of transparency and neutrality. Of course, there are those who will accuse it of being "too" transparent, dry, analytical, what have you. It does ride the edge pretty close, but IMHO it is supremely listenable. So far it's the closest I've gotten to my goal of neutrality while still being musical.
