Can I use RCA Y adapters on c.d. player to feed head-amp and integrated at same
0 Members and 1 Guest are viewing this topic. Read 1338 times.
Huck
HI: Just wondering if I can use these http://www.thesourcecc.com/estore/Product.aspx?language=en-CA&catalog=Online&category=Audio+Plugs+%26+Jacks+Adapters&product=2740501 from my c.d. player left and right outs to feed  an integrated amp and also a headphone amp, simultaneously, without any harm to the c.d. player, rather than rehooking rca's up to listen to one or the other?! Thanks, Huck
hoosier21
yes you can.
Huck
yes you can.
  Thanks! Now does it matter if both integrated and head-amp are both turned on together, or should I turn the "unused" one "off"? Thanks, Huck
MLS
I am all ears on this issue also.
hoosier21
It won't matter  think of it this way, if you have a preamp with dual outputs, these dual outputs are really just a second output split off of one output, like this y connector you are buying is doing. With this set up, you would not worry if the power amp and headphone amp (each one hooked up to dual outputs) would you? Anyway  hook them up, don't worry if one or both is on.
Huck
  Thanks a lot! Huck
