TT Cartridge???
0 Members and 1 Guest are viewing this topic. Read 1474 times.
chgolatin2
TT Cartridge???
« on: 17 Jul 2007, 07:14 am »
Whats a good cartridge that doesnt cost you an arm and a leg?  Any recommendations would be appreciated!  My clearaudio emotion tt needs to rock :thumb: :green: aa
Daverz
Re: TT Cartridge???
« Reply #1 on: 17 Jul 2007, 10:08 am »
What's your budget?  I think the Dyanavector 10x5 is a great cartridge.  Warm, spacious, good bass, good tracker.  Goes for about $380.
Wayner
Re: TT Cartridge???
« Reply #2 on: 17 Jul 2007, 11:36 am »
If an MM is O.K. is suggest an Audio Technica AT440MLa. $100
W
woodsyi
Re: TT Cartridge???
« Reply #3 on: 17 Jul 2007, 12:55 pm »
Is your TT fitted with satisfy arm and Arum classic wood cart?  If not what?  What phono stage are you using?  Oh, and yes -- what is your budget?
aod
Cartridge Recommendation
« Reply #4 on: 19 Jul 2007, 09:23 am »
Consider the humble Denon 103R
A very good all rounder.
Output is a little on the low side but
if the phonostage has a healthy gain,
this is a nice cartridge to use.
chosenhandle
Re: Cartridge Recommendation
« Reply #5 on: 19 Jul 2007, 01:46 pm »
"all rounder"? that is a great way to describe the conical stylus!
lcrim
Re: TT Cartridge???
« Reply #6 on: 19 Jul 2007, 03:00 pm »
A cartridge should be matched w/ the mass of the tonearm and should work well w/ your phonostage.  A high compliance cartridge, such as the AT 440mla recommended, works best with a lower mass arm.  The Denon DL-103, which is a low compliance cartridge, requires a medium to high mass arm for control.  The gain available at your phono stage may preclude the use of LOMC cartridge as was mentioned above.  You didn't mention what tonearm you are using.
You can consult the manufacturers specifications of your tonearm to get some rough parameters of what cartridges would be a good match.  There is also a vinyl section of this board where more advice is always available.
Edit:  found this online
Satisfy Aluminum
Technical Data:
Effective Tonearm Mass: 9g
Cartridge balance range: 2.5g - 17g
Vertical tracking force (at min. cartridge weight): 3g
Null points: Inner : 63.6 Outer: 119.5
Audio lead:
Length (off tonearm): 1m clearaudio
Sixstream cable fitted with clearaudio MPC connectors or RCA termination box.
Capacitance: 260 pF/m
Resistance: 100 Ohms
Overhang: 17.5 mm
Effective Tonearm length: 9 inches (230 mm)
Distance from pivot to stylus: 222 mm
Did your TT come w/ this tonearm?
« Last Edit: 19 Jul 2007, 04:29 pm by lcrim »
aod
Conical rounder
« Reply #7 on: 19 Jul 2007, 06:04 pm »
Good on you chosenhandle... you caught the pun...  :lol:
woodsyi
Re: Conical rounder
« Reply #8 on: 19 Jul 2007, 06:17 pm »
And I thought you were being elliptical.  :wink:
chgolatin2
Re: TT Cartridge???
« Reply #9 on: 19 Jul 2007, 09:08 pm »
My clearaudio came with the satisfy tonearm, pretty cool looking table to say the least.  Also, I have a Project Phono Stage 2 a basic one
