0 Members and 1 Guest are viewing this topic. Read 26329 times.
For us diy dummies, what kind of baffle do we need and what kind of performance can we expect from 1 of these drivers in dipole?
Hate to nag....what about dimensions?
Mr. Haskins,It would be interesting to see the sims of what a dipole would do. I wrote a good friend recently suggesting that a pair of these per side and a Hemp full-range might be a possibility. Best Regards,TerryO
hi kevin,re: box size, for the 12", you recommend a 3cuft box w/a single port. would a 6cuft box w/dual ports be the ticket for two 12" drivers in a single box, or is it more complicated than that? (and, would i need a 14cuft box for two 15" drivers - yikes!) thanks,doug s.
Oh... one more thing. Wiggins came up with a great concept (I think its his first good idea) for a compact dipole layout. It takes into account the rocking associated with large driver excursions. The drivers are mounted so that their rocking cancels and you get a wide effective baffle width. I'm working on that and just a simple H or W baffle layout with some projected HP passive filters so that you don't need active EQ to use these. All you would need is the baffle (you build), the drivers, the passive network (you build) and an appropriate amplifier.
Quote from: doug s. on 19 Jul 2007, 08:46 pmhi kevin,re: box size, for the 12", you recommend a 3cuft box w/a single port. would a 6cuft box w/dual ports be the ticket for two 12" drivers in a single box, or is it more complicated than that? (and, would i need a 14cuft box for two 15" drivers - yikes!) thanks,doug s.Yes and no... The box sizes are listed PER driver. These really are large box subwoofers when use in typical boxes. They are better suited to IB or dipole use due to the high Qts, lots of displacement. Our up and coming drivers (Shiva-X & Tempest-X) will fit better in more typical box sizes. Box tuning isn't as simple adding an additional port when you double the volume. The relationship is not linear so you have to model the enclosure, with the number of ports & their size to get the correct tunning frequency. What I recommend to people is rather than build one large enclosure with multiple drivers, but two completely different subs. As boxes get larger their panel sizes become problematic to damp. You start to need LOTS of bracing. Your better off having two subs in the room anyway. Two subs will give you a smoother in-room response than a single one (typically). Two subs will have smaller panels and footprints so you have fewer problems with enclosure resonances. Smaller enclosures act more like the modeled enclosure because those panels flex as you get larger. Smaller subs are easier to move and build. Just my 0.02.... take it or leave it.
How big is your room Doug? What do you listen to?
