0 Members and 1 Guest are viewing this topic. Read 13017 times.
Hello Kai, Based on what I read in your sonic preferences, I would consider looking into an EL84 based unit to go with these speakers. The EL84 will give you a sweet, realistic midrange as well as provide you with good dynamics at the frequency extremes and a nice extended, airy upper end. The Jolida 102B is a very good contender as it can be upgraded and taken as far your imagination desires. At 20 watts, it should be plenty. Also, if you can get away with lower wattage, the Almarro 205A MKII should also be looked at. Here you are dealing with 5 watts. There are a lot of nice options out there and all of them can be had for well under $1,000 (even less if found on the used market). I am sure others will chime in with more good considerations.
....in a pretty large room with metal ceiling, sheetrock wall, suspended wood floor, industrial and not very furnished...I like acoustic guitars, some classic, some electronic dub and occasionally it has to rock..
Still in the same room ?yep!
hey provny,yes, the Fi X is still quite high up on my list based on what I hear. Seems like most people think with the XRS it should be loud enough for average listening but not headbangingly so. BYOB...I don't mind the looks that much, I actually think it could be a funny touch in an otherwise nice looking setup but the Fi looks sooooo much better...
For now, I am trying Music References' little box EQ (hehe, does not sound quite like 47Labs shortes signal path and such..). Except this 'lower mids issue' (to my ears, in my room and setup), I like a lot about the XRS and the Shigaraki. So I figured I give this little thing a try before I keep scouting for tubes. Will report back.cheerskai
