0 Members and 1 Guest are viewing this topic. Read 26821 times.
Quote from: lazydays on 6 Jul 2007, 06:53 pmactually the reason so many knives are made from 440C and 416 stainless steels are the ease of machining. 410 would be better along with 17PH4 and a good "16" series. None of these are all that much fun to machine, but have a far better grainular structure (17PH4 being the hardest to work with). gary410? Are you sure that's not a typo or something? As far as I know 410 stainless is used only in the handles & frames of various knives. It's dead soft (around 40 on the Rockwell C scale) and the edge would fold and roll over very easily. I've never heard of 17PH4, but a quick search leads to 17-4PH which has rather similar properties to 410 stainless. Great corrosion resistance, but again, practically no carbon and dead soft, which leads me to doubt its abilities to hold or even take an edge.Generalizing rather broadly, practically every good cutlery steel has at least 0.5% carbon content and a hardness on the Rockwell C scale that's at least in the mid 50's, and usually in the high 50's to low 50's. That's basically what's needed to provide for decent carbide formation for wear resistance along with the ability to take a crisp edge and prevent that edge from folding over & denting during everyday cutting tasks.
This is my Custom made Katana w/ Dragonfly setting. Most beautifully hand crafted piece I own.
Hi Guys,Here is my kitchen knife set... Err rather the portion that I love! I really think if you get anything made in Japan the quality is unmatched period.Shun made in Seki City Japan.
Who made yours? Bugei, Odd Frog, Tenold, SummerChild or something?I'm drooling for a Clark L6 Bainite blade. I want it to last and be able to take use well!Imperial
What do you cut with that knife (second from top) with the divets in it? The divets don't cause problems when cutting?
410 stainless steel will harden, and is much tougher than the 416/440 series. It's just harder to work with because of it's properties. It's also thought to be a little stronger than the other two.
The problem with 410 is that it's harder to gain that last few ten thousandths of an inch (or in this case finish out). But if you know how, it's not all that bad. 17PH4 is a bitch! That's what they make landing gear struts out of for carrier based planes. There also is some experimenting going on with some rifle barrels due to it's ability to handle high heat in tight confined places. 410 and the 17 series steels have less of a problem with cracking than the other 400 series do, but doubt that's a realistic factor here. Still I guess is we wanted something that would handle being tossed in a fire or beat silly then we'd all have our knives made from Hestalloy. Then we could spend weeks trying to hone that edge <g>!
