GK-1
0 Members and 1 Guest are viewing this topic. Read 2681 times.
Tim
GK-1
« on: 3 Jul 2007, 09:47 pm »
Hugh,
Really tempted by the GK-1 pre, can you answer a few questions please?
1. will it work fine into a naim 250 power amp?
2. for a moving coil set up what spec pre would you recommend? how to connect?
3. Is there a remote control option?
4. how does the gk-1 compare to the swift?
cheers from Wales,
                  Tim
AKSA
Re: GK-1
« Reply #1 on: 3 Jul 2007, 11:45 pm »
Hi Tim,
Thanks for your post, great to hear from Wales!
Answers in your order:
Output impedance is around 140R, minimum amp input impedance is 10K.  In short, YES!!
I do not know the market that well, and these recommendations are tricky.  Try to use a SS MC head amp, they are generally quieter than tube, email me privately on this one!
The MC head amp would plug in to the phono input on the GK1, which has a sensitivity of 5mV and carries full EQ.
No, only a switching option.  Only the Swift has remote control.
Same analog circuit, identical performance, some component changes, nothing more.
cheers from Wales
I trust you were not flooded out?
Hope this helps, thanks again for the post,
Hugh
Grumpy_Git
Re: GK-1
« Reply #2 on: 4 Jul 2007, 01:47 pm »
Hee hee I really should get my arse in gear and put the last GK1-R sold in a case of some sort.
Still I'm using the excuse of the purchase of a dedicated listening environment (flat) to convince myself i dont care.
I hate the mechanical side of this hobby.
Nick.
rabbitz
Re: GK-1
« Reply #3 on: 4 Jul 2007, 08:34 pm »
Nick.
I hate the electrical side of the hobby  :lol:
AKSA
Re: GK-1
« Reply #4 on: 4 Jul 2007, 10:17 pm »
I hate the inventory side of the business........ :scratch:
Hugh
EchiDna
Re: GK-1
« Reply #5 on: 5 Jul 2007, 01:46 pm »
3 years - and no case on my GK-1...
doesn't stop it working :)
it doesn't look quite this bad now, but anyway... lets just say the WAF is pretty low!! and the 2 year old toy factor is scarey high!!
