0 Members and 1 Guest are viewing this topic. Read 26016 times.
Wayner - I wish I understood more than 50% of what you're saying here - it SOUNDS important, tho Post some pics so I can wrap my oft-feeble brain around the other 50%.
The cleanest a record ever gets is when it is first pressed.
Also, mold release is a myth.
How many of you that "enjoy" vinyl already had a collection of LPs before and during the early years of CD?
But actually decoding noise from signal in cartridges and preamps.....this, I'd like to hear more about as it's entirely new to me
Prompted by a suggestion by member 'JLM' in an Audio Central topic recently...he and I would like to know 'how do you cope with it' and still wanna' listen to music on vinyl?
Since this thread is about surface noise, and BobRex and others have mentioned the associated equipment, mainly phono preamp.....How does a good phono preamp work to reduce this?I've only dabbled in the budget stages, but think the design of the phono stage has a lot to do with the noise normally associated with vinyl. the first time i spun an LP with the VPP-1 it was like, where'd all the crackle & pops go?if all other variables are constant, how can a 'stage let out less noise? i'm not talking of the husshhhhh sounds that really cheap stages make, but actual groove/stylus interaction noise.Scott F is right, its easy to get a bit scared of vinyl after hearing us yalk. the underlying theme though is that vinyl is fun, right???
