0 Members and 1 Guest are viewing this topic. Read 25990 times.
Prompted by a suggestion by member 'JLM' in an Audio Central topic recently...he and I would like to know 'how do you cope with it' and still wanna' listen to music on vinyl?
more advanced stylus profiles
Quote from: TheChairGuy on 5 Jul 2007, 02:07 pmmore advanced stylus profilesWhat stylus profiles are you using?
Hi 'andyr' - my records are very quiet due to cleaning ritual and more advanced stylus profiles, as well (180g virgin, or not). Member 'JLM' expressed this sentiment to me - as he only listens to CD now - and I thought it would make a good and provocative new post. Several pages on, and counting - it seems it has
Even clicks and scratches are less audible on a Rock V. It has long been appreciated that most ticks and small scratches on records are equivalent to a single cycle of 10-15 kHz, in itself barely audible; and yet these same scratches throw most record playing systems into resonances which can last up to 50 times as long as the original tick, and are certainly very audible. In the Rock V, resonances right across the band are so well suppressed that for once we can approach closely the ideal of the inaudible tick. The effects are simply over so fast that the ear does not notice, and mildly 'clicky' records can become enjoyable once again.
CDs? Pah!!
First of all the records need to be really clean obviously, but and I know this is going to upset a few but the only way I have found that truly gets them (SNDC) surface noise dead clean is using PVA glue ...In my method I paint both sides thinly and let is dry off till clear, which takes about 1 hr or so, then peel it off which can be hard. Then I use a mix of very dilute truck wash, dishwashing liquid and distilled water to scrub any leftovers out plus clean the loosened rubbish with a stiff but very high quality paint brush, the discs are then rinsed in distilled water and left to air dry. When dry the discs are treated with Last preservative and ready to play.CheersZero One
