0 Members and 1 Guest are viewing this topic. Read 26013 times.
Finally and this is something I really need to look further into I have found that the lower the circuit noise of the phono preamp the lower the apparent surface noise, I am not totally sure why but I have found this to be a real issue, perhaps someone may have a comment on that one. I found that when I went to full battery power for my system that apparent surface noise took a neat dive and low level musical detail took a nice ascent.On the whole I think this is a fascinating topic and worth lots of investigation. CheersZero One
RIAA equalization is therefore a form of preemphasis on recording, and deemphasis on playback. A record is cut with the low frequencies reduced and the high frequencies boosted, and on playback the opposite occurs. The result is a flat frequency response, but with noise such as hiss and clicks arising from the surface of the medium itself much attenuated. The other main benefit of the system is that low frequencies, which would otherwise cause the cutter to make large excursions when cutting a groove, are much reduced, so grooves are smaller and more can be fitted in a given surface area, yielding longer playback times. This also has the benefit of eliminating physical stresses on the playback stylus which might otherwise be hard to cope with, or cause unpleasant distortion.A potential drawback of the system is that rumble from the playback turntable's drive mechanism is greatly amplified, which means that players have to be carefully designed to avoid this.
The reason to isolate heavy instruments from softly recorded instruments in multi-tracking is from an effect called bleed through. Bleed though can also occur between wrappings of the analog tape on the reel itself. The magnetic field on the tape is so strong, it influences the next layer or 2 of tape on top or underneath. You sometimes here the effect on vinyl when you faintly hear the recording start before it actually starts. That is the bleed.W
