sticky buttons on SP1.7 remote
0 Members and 1 Guest are viewing this topic. Read 1540 times.
b5pt9
« on: 26 Jun 2007, 01:22 pm »
Any maintenance procedure for the buttons on the SP1.7 remote?  They're getting sticky and hard to push after it hasn't been used for awhile.
  • The Demo is Everything!
    • http://www.bryston.com
Re: sticky buttons on SP1.7 remote
« Reply #1 on: 26 Jun 2007, 01:32 pm »
HI,
Not heard of that before - if you activate them repeatedly do they loosen up?
Every button is sticky?
james
b5pt9
« Reply #2 on: 26 Jun 2007, 07:01 pm »
Mainly the power button, and the up/down volume to some extent.  I'm away for 10 day stretches at a time, and when I get back the buttons have to be pushed extra hard the first time.  They kind of "snap" down once they move, then they're OK for the next few days.
The previous owner may well have spilled something on it.  Can I disassemble the remote to clean it?  Or maybe take some rubbing alcohol on a Q-tip and try and get around and under the buttons?
Thanks and sorry to bother about such a trivial thing.
Rich
« Reply #3 on: 27 Jun 2007, 02:05 am »
Rich
Sure - have a look and give it a good cleaning.
james
