resistor color codes
0 Members and 1 Guest are viewing this topic. Read 2049 times.
Gordy
« on: 24 Jun 2007, 01:56 am »
Hi All,
I'm building/stuffing a kit tube rectified power supply and have no experience with reading the color codes on resistors.  With what I have vs. what I need, I've come up with the following and would really appreciate it if somebody could confirm and/or correct my assigning of values for the following:
red - purple - orange = 27k
red - black - yellow - gold = 200k 5%
yellow - purple - orange - gold = 47k 5%
brown - yellow - black - orange - brown = 140k
brown? - black - white - gold?  = 100k, this one has a rust colored body and is hard to 'read' but, process of elimination makes it a 100k, I hope!
Thanks for any help you can provide!
Gordy
koiman
Re: resistor color codes
« Reply #1 on: 24 Jun 2007, 02:48 am »
Gordy,
Try this web site it might help.
Lee :D
http://xtronics.com/kits/rcode.htm
Gordy
« Reply #2 on: 24 Jun 2007, 03:13 am »
Thank you Lee!  I did use a similar chart but, being a newby and a nit, I wanted to run it passed those who know for a nod before soldering them in  :thumb:
tanchiro58
« Reply #3 on: 24 Jun 2007, 03:42 am »
http://www.elexp.com/t_resist.htm
This is another one or you can calculate your resistors by using this below
http://www.csgnetwork.com/resistcolcalc.html
randytsuch
« Reply #4 on: 24 Jun 2007, 04:06 am »
Or you could use something like
Bad boys rape our young girls buy violet gives willingly  :wink:
There are other versions, but this is the one that I have used lately.
edit
Oh, I just checked the link, and saw that they have a version that is close to mine, but I guess ravish is more PC than rape.
Randy
Gordy
« Reply #5 on: 24 Jun 2007, 04:09 am »
Thank you Tan, the calculator is sweet!  The first three check out, I need to look at the bands of the last two again  :roll:
randytsuch
« Reply #6 on: 24 Jun 2007, 04:14 am »
Gordy
For a serious suggestion, get a DVM.  You should have one, to make sure the power supply is working right, and it is easier to use a meter to figure out a resistor value than by reading the color codes.  Even if I figure it out by color codes, I always feel better when the meter verifies it.
Randy
Gordy
« Reply #7 on: 24 Jun 2007, 04:21 am »
Randy, you're back!  :thumb:  I've an antique Simpson VOM, it'll only give me ohm readings up to the 100x band, the 10k band is shot.  Guess I do need to spend some money on a digital...
randytsuch
« Reply #8 on: 24 Jun 2007, 05:34 am »
Hi Gordy
Back, but just for a bit.  I am actually leaving for a pretty long vacation on Tuesday, which will be followed by a business trip, so I will be gone for almost a month.  Am taking the family to Korea and Japan  :thumb:.
Randy
Gordy
« Reply #9 on: 24 Jun 2007, 11:32 am »
Excellent Randy, and as Chris/Wolfie would say... Take lots of photo's and post them in your gallery  :D
JohnR
« Reply #10 on: 24 Jun 2007, 11:50 am »
Doh! Forget it! My mistake.
But, do measure before soldering :thumb:
