0 Members and 1 Guest are viewing this topic. Read 19963 times.
Quote from: lazydaysactually I think the real home run in a 10 meg DSLR is with the Pentax. You can use the common film camera lenses with it, with out a penalty like you do with a Nikon or fuji.The D40 and D40x are the only cameras in Nikon's current DSLR line that can't drive older AF lenses. Once you step up to the D80 (also 10MP) and above, you can drive almost anything. I routinely use my old film lenses (Tamron, Sigma and Nikon, both AF and manual) on a D80.Quote from: lazydaysIf you buy a Nikon, forget their lenses. They just ain't what they used to be. Lots of plastic inside of them anymore. I use almost nothing but Sigmas and Tokinas due to their quality.For reference, specifically which Nikon lenses did you find inferior to which Sigma and Tokina lenses?Personally, I don't mind high quality plastic for lens barrels, as it is lightweight and seems better at withstanding impact (mental dents, plastic rebounds). Plastic for the lens elements is another issue, although I haven't heard any such details regarding Nikon lenses. I know they specifically mention glass for the ED elements, but I haven't seen details for the other elements.Quote from: lazydaysAnd while on the subject of lenses, rumor has it that the Schnider lenses will be standard OEM equipment on the Pentax camers in the near future. These lenses are about as good as it gets in a digital camera.Are those lenses actually manufactured by Schneider, or just designed by them? I've read that some point-n-shoot cameras advertise Zeiss glass, for example, but it isn't actually manufactured by Zeiss or subject to their quality control. Penetrating all of the marketing language can be exhausting at times...
I see what you mean. This is on 12mm, widest you can get on a digital w/o going fisheye.
Go Canon!! You can get adapters to use so many different lenses - including Nikon. I'm running contax, zeiss, pentax and nikon lenses on my 30D - so many cheap and great lenses out there! That aspect alone is a *very* cool bonus.When Canon went to the EOS mount (from the FD mount) they made the bayonet diameter much larger and moved the mount closer to the film plane. This has very significant advantages:- Allows for faster lenses. The larger mount simply is a bigger hole for the lens designers to work with. This is why Canon is the leader in sport/news/journalism photography by a vast margin.- Less compromises with wide angle lens design. Since the mount is closer, the rear element of the lens can be closer to the film plane. This simplifies wide angle lenses significantly, thus improves quality. Since the rear element can now be closer to the film plane, and therefore the point of ray conversion, less optical trickery is involved. This is why rangefinder cameras typically have the best, and smallest, wide lenses - there's no SLR mirror in the way - allowing the rear element to get really close to the film. With the EOS mount, you're closer. This is also why you can use a wide variety of other lenses on your Canon - nobody gets their lenses as close - so the adapters have a few MM's to exist.The EOS mount is unarguably superior.Another advantage of EOS is the USM focusing - ALL lenses have the motor in the lens - and all USM motors have the motor build directly right onto the lens element harness. Fast near instant silent focusing! Nikon has the auto focus motor in the camera body, which connects to the lens barrel through a series of linkages. Not ideal.Canon's also have vastly superior interface design, IMHOPro for Nikon? Nice flashes - a very elegant and advanced system. Canon flashes are good, but Nikon wins hands down. This doesn't compensate even slightly for the above points, however.Regardless, either way you go, it's more the user than the gear. Both SLR's are delightful pieces of equipment.Cheers/A
Quote from: Levi on 24 Aug 2007, 04:45 pmD200 uses CCD , D2H uses LBcast while D2X uses cmos sensor much like the D3. Go figure. The difference is the D200 and D2x sensors are made by sony, the new D3 sensor are an original Nikon design built by an undisclosed and apparently super-secret 3rd party.
and you will sooner or later get the infamous "error 99" for free. And Cannon wont fix it cause they can't.
Quote from: Levi on 23 Aug 2007, 04:01 amI see what you mean. This is on 12mm, widest you can get on a digital w/o going fisheye.not being critical, but what about the Tokina 10mm to 17mm zoom? I don't think it's considered a true fisheye. Have not been able to lay my hands on one to see.gary
I guess I was referring to Nikon digital lens. Correct me if I'm wrong, 12-24mm is the widest Nikon dx lens you can buy without fisheye.
Quoteand you will sooner or later get the infamous "error 99" for free. And Cannon wont fix it cause they can't.That's a bit of an exaggeration of a very rare problem Nikon does have better flashes, for sure, but If you're serious about flash, you'll use a Metz (even if you're a Nikon guy...)Let's see what the pros use, and we can make it a game called: Find the NikonTruth is, they're both great systems. There's no blaming the gear for any bad photos. aa/A
I am here to say Canon DSLRs rule!Nikon blows~ Nani nanaMike
QuoteI guess I was referring to Nikon digital lens. Correct me if I'm wrong, 12-24mm is the widest Nikon dx lens you can buy without fisheye. Yup, that's right. That's the limit on a DX (currently)
the error 99 condition is not all that uncommon. I've personally seen three cameras go back to Canon with it, and the guys on Shutterbug have disscussed and cussed it several times.
Quote from: AdamM on 31 Aug 2007, 11:18 amQuoteI guess I was referring to Nikon digital lens. Correct me if I'm wrong, 12-24mm is the widest Nikon dx lens you can buy without fisheye. Yup, that's right. That's the limit on a DX (currently)There's also the Sigma 10-20mm that comes in all mounts. I've owned it and it's a fine lens on my Nikon bodies.
It's like photographic carpet bombing!
