MWS info on teflon magnet wire, one of 23 diff types of coverings (1-4 layers thick available) that I lumped into the phrase "Enamel", this is where a lot of people get confused because this is the common term used. One must study the different types to gain any understanding about magnet wire.
inserted update-quickThe easiest & fastest way to study the coverings offered, simply click on the various Thermal Classes once you hit the link (each temp has about 3 diffrent insulations described):
http://www.weicowire.com/tableofcontents3.htmINSULATION INFORMATION:
Temperature Class: 200° C
Insulation Type: Polytetrafluoloethylene (Teflon)
MWS Code: TEFLON NEMA Specification: None
Federal Specification: None
IEC Specification: None
Insulation Characteristics:
High heat resistance, excellent resistance to most solvents, acids and corrosive chemicals. High dielectric constant.
General Applications:
Miniature rotating components and windings where severe environments are encountered.
some of info from the link below
Thanks Fast Eddy
I do think your worry is justified, in the sense of traditional uses of different types of wire and their typical applications, it is a fact magnet wire being used for a power cord is certainly out of the norm. Although magnet wire is in fact laced through out our society in electric devices everywhere (it is not to my knowledge ever used in a power cord), a look at the 2 links below would give anyone a much better understanding of its qualities and standard uses.
I do feel that many of the coverings are far far far more durable than most believe, study the links!
Anyone who has any concerns should simply not use it for power cords plain and simple
, not complicated at all.
Anyone who wants to do power cords needs to
weigh the risks, and DO YOUR HOMEWORK! In fact Fast Eddy has pointed out the places where it could be a problem.I do disagree that the structral integirty of the covering is as fragile as he percieves it to be.
if anyone is unwilling to study both of these charts and each type of wire covering throughly you are on your own to speculate what ever you chose 23 types:
http://www.mwswire.com/awgsearch1.asp15 types:
http://www.essexgroup.com/Products_Services/Magnet_Wire/http://en.wikipedia.org/wiki/Magnet_wire
