Big Honk'n Isolation Transformer
0 Members and 1 Guest are viewing this topic. Read 1392 times.
2wo
« on: 8 Jun 2007, 10:22 pm »
I will try to link an image. If I get I will come back and explain it
OK, so that kind of worked. I went and bought two pair of the Signal transformers to build my own Felicia.  I salvaged what I thought was an old UPS to use as a chassis.
Well, well, look what I found when I opened it. That isolation trans is about 10" across and rated  for 15 A
Gee what to do now? Any thoughts?…John
« Last Edit: 8 Jun 2007, 10:35 pm by 2wo »
Occam
Re: Big Honk'n Isolation Transformer
« Reply #1 on: 9 Jun 2007, 06:43 pm »
John,
I split your post into another thread. I assume that big toroid is an isolation transformer. (I'm also assuming that the metalic bolt in its center has an insulating bushing at the bottom to prevent a 'shorted turn'). Could you post some more information? What is the make and model #. How is the transformer? hooked up; how many leads, is there a green or green/yellow striped wire coming from the toroid and what is it connected to?
Paul
2wo
« Reply #2 on: 12 Jun 2007, 02:42 am »
Thanks Paul,
Yes it’s an Isolation trans, not balanced, Two leads in, two out. There is a filter network on the output two 15uf caps from hot-neutral-ground and a resistor small cap in there as well. I have not had a chance to take it out and trace it out.
The center bolt was insulated but it made me nervous and I have already removed it.
I think it will work well for my power amp. Now I am looking to integrate  it with my low power  stuff. Maybe carry on with  the Felicia or maybe add a couple of CMC to the output outlets…John
