Alpha vs LS6 vs OB-7
0 Members and 1 Guest are viewing this topic. Read 2165 times.
Snegrah
« on: 9 Jun 2007, 02:04 am »
Danny:
I think I read somewhere you said that the OB-5 was one of the best speakers you've designed?!?!?!?   :scratch: OK...what about my Alphas????  How do the Alphas compare to the OB-5, OB-7 and the LS6's????  I'm still hooked on these Alphas and enjoy them immensely!  :banana piano:
Tom
Danny Richie
Re: Alpha vs LS6 vs OB-7
« Reply #1 on: 9 Jun 2007, 07:28 pm »
Check this thread out: http://www.audiocircle.com/index.php?topic=34105.0
The LS-6 improves on the older Alpha LS design with better drivers. The woofers are higher quality and use a more advanced motor structure. The result is better resolution and detail levels and cleaner vocal range.
The new M-165ls woofers also allow it to play lower than the older Alpha LS, but the Alpha LS does have a higher sensitivity.
The new tweeters in the LS-6 offer improved dispersion and an improvement in imaging.
Snegrah
« Reply #2 on: 11 Jun 2007, 07:48 pm »
OK...that'll do it.  Thanks for the response and BTW the new website is great!
