0 Members and 1 Guest are viewing this topic. Read 6471 times.
Tower 2.5-way....will it best the 2641?
Mr. Haskins,Congratulations on your new driver, it certainly is attractive. From the sound that you have heard during your listening sessions, would you say that these would sound as good driven by a Chip-amp? I know that you are used to high-end systems, but would a more middle of the road system also benefit by the use of these drivers in a speaker?Wishing you every success with your new products.Best Regards,TerryO
I'd like to see vendors venture more into active speakers for audiophiles. Comparing the Paradigm Studio 20 versus Active 20 was one of three audio ephiphanies I've ever experienced. (Damn, I should have bought those things. )IME software should be limited to the design of speakers. Poor quality drivers and improper cabinet designs can't be fully "fixed" with software. (Can't turn a pig's ear into a silk purse.) You can bend the laws of physics (trading one parameter for another) but they're called "laws" for a reason. For instance EQ is best subtractive, not additive and of course EQ is room dependent. Adding bass extension comes at the price of reduced efficiency and with loss of efficiency, reduced dynamics. Plus lots of extra power will be required. OTOH an active speaker with a 6.5 inch woofer won't need much additional help for reproduction of most music.
Quote from: TerryO on 10 Jun 2007, 10:52 pmMr. Haskins,Congratulations on your new driver, Even Radio Shack systems will benefit from better drivers Terry. I was listening to my Optimus clock radio the other day and out of curiousity I opened it up to see what kind of amplifier was driving the 2" full range driver. Low and behold... I think it was a chipamp! At least it was made from chips..... Those Radio Shack engineers are pretty smart. I'll send you a couple drivers if you want to kludge together something for the DIY event.
T/S Parameters based upon an average of eight measured units. All measured at the same time in the same way with the same input signal. All broken-in for 24 hours with continuous 30Hz test signal at roughly full excursion (22mm PP).Qts = .296Qes = .3985Qms = 1.15Fs = 36.11 HzVas = 33.5 lmms = 13.56 gcms = 1.434 mm/NBl = 7.03Spl = 88.02If you run the math it won't add up because these are averages of eight units. I saw VERY little variance on the fundamental values (Re, Le, mms, cms, Bl). Good indicator of the Q/C & production tolerances used. The parameters pretty much are RIGHT ON with what we aimed for. These are great mid-sized vented alignment drivers. Almost an exact drop-in replacement for a Seas CA18RNX with the exception that we have twice the linear excursion and a fraction of the Le.
I have a couple tweets for you if you like. I've tested more tweeters than I care to have hanging around the office. It does about 24-25mm peak-peak before you get any suspension noise that starts to sound objectionable in free air. The linear BL limits via the Klippel measurements show about 21-22mm PP as a more accurate X-max measurement though. I'm going to go to Radio Shack to pick up another one of those clock radios while they are on special. I figure with some Hexfreds, a couple cryo treated Teflon caps, better regulators, new lytics and maybe swap out those cheap opamps for the LM4562 biased into Class A operation these things could be giant killers. I might change out that captive power cord with a IEC connector so I can roll some power cords too. You never know how much that power cord can open up the dynamics in your dual mono clock radio. I'd disable the LEDs though. Those things wreck havoc on your microdynamics.
