0 Members and 1 Guest are viewing this topic. Read 2203 times.
Well worth it for the cartridge, arm and arm mods alone. And a Rega should be easy to ship as it's a very simple table. I assume he'll remove the cartridge for shipment. So you'll need a protractor to align the cart. I like this paper one:http://www.vinylengine.com/download_centre/index.php?rega_arc_baerwald.pdf (PDF file)I can't tell if he has a spacer on the arm for the Dynavector, but I'm sure he must as it needs it just for clearance. I used a 4mm spacer for the 10x5, some people use the 2mm (it also depends on how thick your platter mat is). Once things are settled in, you might consider adding the Michell VTA adjuster and finger nut so you don't have to remove the arm or use tools to adjust VTA.http://www.artech-electronics.com/us/products/michell/mich_upg.html (toward bottom of page). Their Rega clamp is OK, too, but I prefer the KAB clamp as that won't hurt the record if you drop it.
Dave-did you use the standard felt mat with the spacer? I have a Herbies mat that I am planning on using with the P3. Thanks.
