0 Members and 2 Guests are viewing this topic. Read 53665 times.
has there been any more developments with this?anyone tried comparing the sound of the SC transformers with the suggested alternative?I would do this, as its an easy swap out, however those transformers seem more readily available over in the US.Brad
I only have data for the 22083 and 22160.
But as for the Newava part that you somehow managed to get hold of.........I only have data for the 22083 and 22160.Pat
Transformers with shields are not worth diddly. Besides lower capacitance, it adds a big chunk of capacitance to ground. (What did they think that a big hunk of capacitance to ground was going to do?)
I know a few guys here who are. A few seem to know their stuff. Some of you may want consider approaching them, and seeing if they are interested in making TX/RX PCBs.Pat
F100,I found that the transformer sounded best in the Paridisea, not the squeezebox and even worse in both.It seems that the TX part of this is more complicated than the RX when using transformers - if you are inclined I wwould try the transformer in the DAC and not the SB.Brad
You mean to tell me that:1.) None of them have something like this already built to sell to you guys.
2.) None of them see this as way to make $$ by spending 1/2 hour laying out a PCB, and......3.) They charge 3 times what I do? With minimum qualifications? Good grief......
BTW.....when did this become a DIY site? I heard that the emphasis was to go away from that.
