0 Members and 1 Guest are viewing this topic. Read 4700 times.
I have two different parts to each question. (1 is would the below be safe electrically) and (2 would the below possibly cause a different presentation to the music vs. equal size return and signal wires) ie; more bass, less bass and so on?A-Does anybody know advantages and disadvantages off using a return leg that is larger than the signal wire, say the return is 18ga and the signal is 30ga.?B-Does anybody know advantages and disadvantages off using 2 returns say 22ga. instead of 1, still using a single signal wire? Can this be done - at least not be dangerous electrically? If so I can try the various combos and rev. the audio qualities on my own.Thanks in advance,
Does anyone have any theories or experience with using different materials for signal and ground legs? Do both conductors affect sound equally?Thanks!
Andyr I made a 30ga mag wire IC just a single wire run and it has great articulate bass that knocks me over (could the 18ga return be helping the bass, no clue- need more prototypes) and it is not twisted. From my limited understanding but insane hours of reading research from what I understand twisting has an effect of extending HF on single + and single - not twisted magwire Anrti-Cable SC, does it apply here, no clue. I do understand twisting to have good noise rejection qualities.Anyway I can't wait to try out your ideas and see how they work now that I do not have to worry about electrical fires, blown amps and the like . (although if the enamel wears off 2 wires in close proximity on my many multiple mag wire PCs I'll see you guys in the afterlife ). Think I'll reduce these to just 3 14 ga. wire?! What I need now is a good robust but cheap RCA I can use for each prototype, I will eventually use eichmanns when I decide on a keeper.
"However, I would say a better result would be obtained by using 3 x 30g wires for signal and 1 x 24g wire for earth/return ... this is what I use for my ICs and hookup wire inside amps."I thought I'd try this style first, and see what I think and go from there. Any choices you like in RCAs? Thanks,
Quote from: PJ234 on 13 May 2007, 05:19 amDoes anyone have any theories or experience with using different materials for signal and ground legs? Do both conductors affect sound equally?Thanks!Why would U want to use different materials?Regards,Andy
Cost!My thinking is that if the center pin conductor is the one that most influences sound, using the very best or most expensive conductor here and something less expensive for the ground would save significant $$.For example, I have been playing mostly with magnet wire on my IC's. I'm wondering if I were to continue to use the magnet wire for the ground, but other 'better' conductors for the center pin, if this would have the desired effect.
