Soldering stations
0 Members and 1 Guest are viewing this topic. Read 5699 times.
guest1632
  • Guest
Re: Soldering stations
« Reply #20 on: 25 May 2007, 03:53 pm »
Hi Ray Bronk,
It is 2 inches from the rubber grip to tip. This solder station is awsome. The melting point is fast and it is adjustable in degree and it let you know when the tip is ready to use by beeping. Good luck.
Tan
Hey Tan, Thanks for the info. Yep, that's the one for me.
Ray
ViperZ
« Reply #21 on: 7 Jun 2007, 06:11 pm »
My first post on this forum...
If you have funds, I'd highly recommend Weller soldering stations. There are some in $100-150 dollars range with adjustable temperature range. I think WES51 is the most used station around.
Personally, I use Solomon soldering station. Cost me around $80-90 a few years ago. Works great, pretty much as good as Weller stations. Don't remember exact model #, but my station has analog readout - similar to SL-30 station, but SL-30 has digital readout.
