0 Members and 1 Guest are viewing this topic. Read 5683 times.
Ray this is the best buy out there in terms of price. I have one and it works great. The one that Scott has is a little better than this but a little more expensive. I bought this one on the recommendation of John Hillig of Musical concepts. He uses one on his work bench and loves it. SturgusSmall reviewhttp://www.eham.net/reviews/detail/5777http://www.circuitspecialists.com/prod.itml/icOid/6438
Hi, I called CSI, and talked to this guy Nolan. A 10 degree variant up and down is quite a bit. So then I ask him about the Solomon versus there brand, does the Solomon have the tray for the iron built on the base? He asked if I was on the site, and I told him Yes, but I was visually impaired. He immediately hung up. Go Figure.Ray Ray this is the best buy out there in terms of price. I have one and it works great. I bought this one on the recommendation of John Hillig of Musical concepts. He uses one on his work bench and loves it. SturgusSmall reviewhttp://www.eham.net/reviews/detail/5777http://www.circuitspecialists.com/prod.itml/icOid/6438
Quote from: sturgus on 10 May 2007, 11:25 pmHi, I called CSI, and talked to this guy Nolan. A 10 degree variant up and down is quite a bit. So then I ask him about the Solomon versus there brand, does the Solomon have the tray for the iron built on the base? He asked if I was on the site, and I told him Yes, but I was visually impaired. He immediately hung up. Go Figure.Ray Ray this is the best buy out there in terms of price. I have one and it works great. I bought this one on the recommendation of John Hillig of Musical concepts. He uses one on his work bench and loves it. SturgusSmall reviewhttp://www.eham.net/reviews/detail/5777http://www.circuitspecialists.com/prod.itml/icOid/6438
Quote from: Ray Bronk on 11 May 2007, 11:17 pmQuote from: sturgus on 10 May 2007, 11:25 pmHi, I called CSI, and talked to this guy Nolan. A 10 degree variant up and down is quite a bit. So then I ask him about the Solomon versus there brand, does the Solomon have the tray for the iron built on the base? He asked if I was on the site, and I told him Yes, but I was visually impaired. He immediately hung up. Go Figure.Ray Ray this is the best buy out there in terms of price. I have one and it works great. I bought this one on the recommendation of John Hillig of Musical concepts. He uses one on his work bench and loves it. SturgusSmall reviewhttp://www.eham.net/reviews/detail/5777http://www.circuitspecialists.com/prod.itml/icOid/6438Hi Sturgus,Does that Solomon iron detach from the base, or is it hardwired in there?I was looking at there list of extras, and it said the iron is hardwired in? So how do you replace the element if it burns out?Ray
A couple questions for those with the cheapo CSI station when using just for circuit boards (through holes, not SMT):- What tips do you recommend besides the stock one, just for pcb's soldering - the usual black gates, resistor replacements, etc. ? I figure if I buy 3 or 4 more tips I'll get to the $50 freebie deal, but wasn't sure what to get.- Does it make any sense to go to the lead free version? It looks quite different. I'm using Star Sound's silver bearing solder on "standard" pcb's but will always have a mix of silver and non-silver for projects. Just stick with the basic version and use it for both?TIA,Tom
Ray Bronk,I just got the lead free solder. What is your suggestion of other tips? :scratch:Thanks.Tan
Hi Ray Bronk,I got the lead-free solder station. Sorry for the typo (bad english!!!). Since my old Hakko 936 screwed up my works I have to get a best one (best of the good) but paid less, why not? So what kind of tips are you using for little tiny works like SB3 components and other common solding on PCB like replacing capacitors, resistors, surface mount chips, etc... How many differnt tips are you using now? Tan
I've got a cheap CSI station ($35). If you spend $50 you get a free multimeter [a cheapie, but its FREE].Because its so cheap I've seen a few recommendations for it around here and other audio siteshttp://www.circuitspecialists.com/prod.itml/icOid/7307
