0 Members and 1 Guest are viewing this topic. Read 7927 times.
Basicly most low level consumer gear is incompetently designed for no reason.Loudspeakers and power amplifiers are something that you must throw money at and plan well to achieve top notch performance.However low level circuits where everything can be class A can be built for flawless performance without spending a lot of money.Not too much anyway, I would recommend manufacturers spring for quality DAC's, ADC's and OP-AMP's for buffering outputs and differential inputs.The garbage mentioned in that article is just rediculous (as well as being the norm) if an "engineer" doesn't know better than to make foolish mistakes like those mentioned in the article they should step down and pick out a broom or mop or something they could use that allows them to contribute something.What that article is talking about is basic common sense and there should be no reason for it.How carelessly so many things are designed is a real issue though.
I don't have any use for teflon capacitors unless maybe I'm working with radios or sample and hold circuits.Polypropylene capacitors are about as perfect as you could expect a componet to be for audio.
Quote from: Daryl on 23 Apr 2007, 03:23 amI don't have any use for teflon capacitors unless maybe I'm working with radios or sample and hold circuits.Polypropylene capacitors are about as perfect as you could expect a componet to be for audio.Have you heard Teflon caps in an audio component? Maybe the Sonicap Platinum?
Hey Mr Moderator (Occam),Can we just send this thread to the IGW or Fight Club? This is going to turn out like any other battle regarding objectivism and subjectivism. Maybe I can speed your decision along a bit......Daryl an you other people that live and die by theory,Unless you are willing to actually LISTEN rather than regurgitating theory that we ALL know, maybe you shouldn't contribute to threads like this. In fact, I'd like to suggest a ban on ALL posters who summarily dismiss the viability of ANYTHING that don't have FIRST HAND, REAL WORLD EXPERIENCE with the item(s) being discussed. That sure would eliminate the udder stupidity that is going to take place in the rest of this thread.Did you really just condone the use of aluminum electrolytics as coupling caps in audio gear Have you lost your mind or have you been deaf from birth? .....good grief......
