0 Members and 1 Guest are viewing this topic. Read 14846 times.
White wire (Pin #5, 6 and 7) go to the ground connection of the IEC .
F100 and Gary,I found out another ways of mod which is mixmatched between Mauimods and Floating Shields. This mean using Mauimods (pins 5,6 and 7 to ground) on SB3 and Floating Shields (pins 6 and 7 which are shielded float and pin 5 to ground) on your DAC. With this you have an extended soundstage but not weakening defined mid and high like I mentioned before. Bass is still defined and dynamic.
F-100, when are you going to start offering mod to benefit the un-skilled mass like me??
Quote from: 95bcwh on 23 Apr 2007, 02:03 pmF-100, when are you going to start offering mod to benefit the un-skilled mass like me?? For you, it will be my pleasure. Send me the DAC or your SB3 and I'll be gladly perform the mod for you.
Wow aa aa, ...you're going to drive the modders out of business if you continue to offer deals like this..
I think there is another version that might be worth trying out if you aren't tired of playing with these different combinations. I think we want to ground both pin 5 and shield (6,7) but to different places. Pin 5 should be grounded very close to the output (near R66 in the SB3) or near to the input jack in the DAC. Looking at the pictures that F100 posted, that would mean grounding pin 5 very close to the solder pad where F100 wired the yellow wire. There is a ground solder pad right there that could be used.Then the shield should go to a very quiet ground. This would be the place where F100 wired all the grounds in the Paradisea DAC.In the SB3 this is probably the input ground connection that you're already using.
I've had few people asking me about my DAC upgrade so I thought I post some pictures of the modification.1) Adding a Scientific Conversion SC947-02 shielded digital transformer to the digital output. SC947-02 wiring diagram:Yellow wire (Pin #8) goto 75 Ohm resistor that resides between the BNC and RCA output jack.Red wire (Pin #1) goto the BNC + and Black wire (Pin #4) goto the BNC -White wire (Pin #5, 6 and 7) go to the ground connection of the EIC .
Close-up of the bottom of the circuit board.
Isn't this SC947-02 installation on your DAC's digital input?I'm looking at a digram of the SC947-02, just to be clear, pins 1 & 4 are on the primary/input side of the SC947-02, and pins 5,6,7 & 8 are on the secondary/output side.
Correct me if I'm wrong... SC947-02 is a 1:1 transformer so I can use either side as primary and either side as secondary.
Quote from: jhm731 on 23 Apr 2007, 05:28 pmIsn't this SC947-02 installation on your DAC's digital input?I'm looking at a digram of the SC947-02, just to be clear, pins 1 & 4 are on the primary/input side of the SC947-02, and pins 5,6,7 & 8 are on the secondary/output side. Correct me if I'm wrong... SC947-02 is a 1:1 transformer so I can use either side as primary and either side as secondary.
