Tube rolling... ease/headache?
0 Members and 1 Guest are viewing this topic. Read 1364 times.
marvda1
  • freelance reviewer: The Sound Advocate
« on: 22 Apr 2007, 03:29 pm »
just thought this would be fun since a lot of people own tube preamps,  how hard or easy is it for you to tube roll?
i have the belles 21a tube preamp and have to remove 11 screws when i want to try a new pair of tubes :cry:
arthurs
Re: Tube rolling... ease/headache?
« Reply #1 on: 22 Apr 2007, 04:10 pm »
16 screws on the VAC Ren Sig MKII.....just flip down the frontplate on the Moscode...guess I have both ends of the spectrum...
rosconey
« Reply #2 on: 22 Apr 2007, 04:29 pm »
ZERO SCREWS aa
its soooo simple with my custom candella case,i made a hole and a cover :thumb:
Kim S.
« Reply #3 on: 22 Apr 2007, 04:59 pm »
My ASL preamp very easy as all the tubes are exposed.  My Monarchy SE-250 monoblocks not so easy.  A total of 16 screws.  Thats one reason I haven't done any tube rolling on them yet!
tanchiro58
« Reply #4 on: 22 Apr 2007, 05:03 pm »
I do not need remove any screws all since I have owned my SEA 8608 Reference tube preamp. The only removal is swapping the a pair of Amperex 8608 white label with a pair of PQ orange label which are more musical. I suggest you not to roll tubes regularly. It might cause microphonics or socket loose.
JimJ
  • Ut Prosim
« Reply #5 on: 23 Apr 2007, 11:38 pm »
My ARC SP-9MKII looks pretty easy to disassemble...but I should have another year or so left in the 6922 before I have to worry about swapping it.
My amps are totally open, so none :)
WEEZ
« Reply #6 on: 24 Apr 2007, 12:20 am »
In my case, (6) screws to remove the top. I just left the top off for a few weeks while I played around with tubes.
Also, in my case, the stock tubes wound up back in the preamp. Some did one or two things better...but in the end, the stock tubes had the best 'overall' balance and low noise.
WEEZ
(in my case, the stock tubes are NOS)
hmen
« Reply #7 on: 24 Apr 2007, 02:42 am »
I had to remove 12 screws for my BAT 31R . After I put in the new tubes I just left the cover off.
Spirit
« Reply #8 on: 24 Apr 2007, 03:07 am »
What a timely thread!
I have never opened my Musical Design SP2B.  The 2 tubes shine thru a little window just like the Odyssey Candella.  Found out today that the tubes inside are Matsusita Nationals.  Ordered a pair of JJTesla to try because I was told that they exhibit great warmth.  Looking forward to trying.
Toka
« Reply #9 on: 24 Apr 2007, 02:40 pm »
WEEZ
What preamp are you using, WEEZ?
Joey B
« Reply #10 on: 24 Apr 2007, 03:30 pm »
Extended Foreplay III . Tubes are all exposed , takes just seconds  :D
