Audio/Video Gear and Systems
Home Theater and Video
Bob in St. Louis
$500(ish) Reciever that can drive 4 ohm speakers or seperate amp?
0 Members and 1 Guest are viewing this topic. Read 1491 times.
Robby L.
16 Apr 2007, 08:46 pm »
Looking at the STR-DG800. $270(ish) but it can't power 4ohm loads.
What Recievers do you recommend that can run 4ohm loads.
If that cost difference is like $400, what would you recommend for a decent 2 channel amp?
Cacophonix
Re: $500(ish) Reciever that can drive 4 ohm speakers or seperate amp?
16 Apr 2007, 08:51 pm »
I've sony str da777es that can drive 4 ohm speakers. It has a 4 ohm switch at the back. Wonderful, wonderful receiver. Look around and you might find one in your price range.
Wayner
Reply #2 on:
16 Apr 2007, 09:45 pm »
I believe the Marantz SR4021 will also drive 4 ohms (80 watts per channel). $399.
W
chriss
Reply #3 on:
16 Apr 2007, 09:51 pm »
How bout this?
http://www.spearitsound.com/nad/C720Bee.asp
A friend of mine has heard this and he was quite impressed
Bob in St. Louis
