0 Members and 1 Guest are viewing this topic. Read 29830 times.
At this point, I don't know if it is worthwhile, but if there is min orders or other impedances to ordering the tx's, do any of you guys want to get together for a mini-groupbuy on these transformers. I am willing to pick one up to test out.
OK, so who is going to organize the group buy from ATI Research for these:http://www.atiresearch-anodized.com/ATI-735U.htmlI dont' have my SB in front of me, but it looks like this would be about the perfect size for a SB transplant with the PSU built right in. We can then have the faceplates (they are easily removeable) sent into Front Panel Express together for laser cutting of the LCD cut out. We'd be the envy of all the squeeze-a-philes.
Well, SC responded almost immediately. It will be $16.50 ea up to 49 pieces. I think I counted 11 here. Builder Brad, did you want a couple, as in 2?
Scott, two of the digital transformers?
P.S.S. for best results you should really use one on each of the sending and receiving ends, i.e. one on the output of the SB and one on the input of your DAC. See reference.
