0 Members and 1 Guest are viewing this topic. Read 9183 times.
Bear in mind the BP Special and BP are quite different cartridges.The original Blue Point used a modified P-mount.The latest BP has done away with that awfulness and uses a conventional mounting.Which version do you have Jonathan ?
Wonder if Play it Again has some more expensive phono stages that you could try out to see how the Unico phono stacks up??
Jonathan,It would seem that they would gladly show you how much better their lovingly-tweaked Linn LP12 stomps your NAD or how their Vendetta phono stage would be a clear upgrade.
...this all gets back to my original question, which was what is the main reason for the 'relative' lack of bottom end (at least compared to the digital sources)? Again, it's only a $100 phono card, so that may be part of the problem, too.
The setup for the 533 'table is pretty basic and straighforward: turn the counterweight so the arm is floating, and then dial the weight forward one full turn per gram. Set the anti skate to the same number, and off you go. I know there is not an adjustment to change the VTA, so I'm not sure what good it's going to do me if it turns out to be set wrong (and is there any way to check the VTA)? Also, does anyone know of a good turntable guru in the NE Ohio area? Maybe I could take it in and have it looked at. Thanks,Jon
Thanks for the reply. it could be the sound of the phono preamp, as well. Thanks, Jon
I know what I'm saying...If you would have experienced a really good power filter you'd understand.
ChuckJosephson wrote: I know what I'm saying... If you would have experienced a really good power filter you'd understand.
As I said earlier bass is a digital strength and barring any gross errors in setup, the deficient bass is most likely due to limitations in the NAD tt.cheerio
Wonder why my experience is different than yours and Doug's?? Just a matter of $$ spent??
It's the player, which is notorious for weak bass. Dan Wright's mods address this problem. Also, power filtration and proper power cord selection have definite influence. Get yourself a ONEAC like Byteme...
