input cables
0 Members and 1 Guest are viewing this topic. Read 6554 times.
guest1632
  • Guest
input cables
« on: 24 Mar 2007, 09:34 pm »
Hi Frank,
Since your gear seems to have high praise and all, was just wondering what input and output/speaker wire you use. I am about to build an amplifier kit and am now getting the internals put together. Ok, guys let's keep the flame down. If you would rather PM me to avoid any issues, go ahead.
Ray
modular747
Re: input cables
« Reply #1 on: 24 Mar 2007, 11:54 pm »
It's best to use salvaged wire from buildings burned out with large amounts of accelerant (to achieve the proper annealing temperature).
guest1632
  • Guest
Re: input cables
« Reply #2 on: 25 Mar 2007, 05:29 am »
Pretty sure he uses copper. Sufficient length is important.
Hello, Actually I was wondering what cable or wire he does use. I don't know if he ever got in to the copper or silver thing. My interest was purely curiosity. I'm not interested in a big debate or anything of that kind. My thinking is if he uses specific cable and it sounds good to him, then it might just sound good to me too. I am interested in the internal wiring, nothing else.
Ray
Wayner
Re: input cables
« Reply #3 on: 25 Mar 2007, 12:33 pm »
I think Frank gets his cables from Radio Shack and Menards.  :D
CE2
avahifi
    • http://www.avahifi.com
Re: input cables
« Reply #5 on: 27 Mar 2007, 11:42 pm »
My speaker wires are 14 and 16 gauge simple two conductor wire from Home Depot or similar for a few cents a foot.
My interconnect cables are a collection of whatever from over the years.  If I need new, I can get them in bulk for about 1.69 a set.
I won't get into the audiophlake debate on which wires sound best at this time.
Frank Van Alstine
CE2
Re: input cables
« Reply #6 on: 28 Mar 2007, 12:23 am »
 :lol: Getting kinda personal there dont' cha think?
avahifi
Re: input cables
« Reply #7 on: 28 Mar 2007, 12:20 pm »
Internal wiring?  Mostly Dearborn 20 gauge solid core, heavier for some grounds and much of the power amp wiring.
Frank
guest1632
  • Guest
Re: input cables
« Reply #8 on: 28 Mar 2007, 02:59 pm »
Frank Van Alstine
Hi Frank,
Let me get more specific. On the internal wiring of your amps, for speaker and inputs what do you use? Like I said, I am building an amp kit, and just would like your perspective as to what you guys use on the internal wiring. No debate desired, just info. Thanks.
Ray
avahifi
Re: input cables
« Reply #9 on: 28 Mar 2007, 06:40 pm »
Look back a post Ray.  For heavier wire in amplifiers, we us 18 gauge tinned stranded and some 14 gauge stuff for critical grounds.  Nothing exotic or magic.
Frank Van Alstine
guest1632
  • Guest
Re: input cables
« Reply #10 on: 28 Mar 2007, 07:49 pm »
Frank Van Alstine
No problem Frank. I prsume you probably use some shielded cable going from the RCA's to whereever?  That is what I want to know? Yep, I did read the post.
Ray
avahifi
Re: input cables
« Reply #11 on: 28 Mar 2007, 11:11 pm »
The only place I use shielded cable is from the input jacks to phono circuits in the units with the phono option, and this is simply a few inches of Belden shielded cable. And from the input jacks to audio circuits in the power amplifiers.  Brand is not critical.  For this I use a spiral wound shield as it is easier to strip and install.
Frank
guest1632
  • Guest
Re: input cables
« Reply #12 on: 29 Mar 2007, 12:52 am »
"from the input jacks to audio circuits in the power amplifiers.  Brand is not critical.  For this I use a spiral wound shield as it is easier to strip and install."
Frank
Hmm, ok, that sounds ok. I probably need about 2 and half feet of the stuff. Like with Belden, any numbers to look at? Or do I just walk in to any electronics store that will sell cable, and ask for cable with a spiral wound shield with a probably stranded center?? Cables can make a difference, but for a little more than a foot from the board to the RCA connector, I don't think I'm gonna worry about the hooplah. Thanks.
Ray
avahifi
Re: input cables
« Reply #13 on: 29 Mar 2007, 07:36 pm »
The shielded cable we use is Belden 9396.
Frank
guest1632
  • Guest
Re: input cables
« Reply #14 on: 29 Mar 2007, 08:01 pm »
Frank
That works. Thanks.
Ray
guest1632
  • Guest
Re: input cables
« Reply #15 on: 8 May 2007, 11:03 pm »
Frank
Hi Frank,
Looking in my local shop, they don't have it. I'm going between a pair of RCA jacks, to 2 inputs of a power amp. Would this stuff be ok, or do you use something different there? Thanks again for the info.
Ray
avahifi
Re: input cables
« Reply #16 on: 9 May 2007, 01:02 pm »
How much shielded cable to you need?  If its just a few feet, e-mail me with your address and I will send you some.
Frank Van Alstine
guest1632
  • Guest
Re: input cables
« Reply #17 on: 9 May 2007, 01:46 pm »
Frank Van Alstine
A couple of feet. You have a PM with the info. Thanks.
Ray
Toka
Re: input cables
« Reply #18 on: 9 May 2007, 03:36 pm »
Frank
Is that the gray wire seen in the photos on your website? What is that, about 3 inches? Sorry, bored at work today.  :oops:
Tubemon
Re: input cables
« Reply #19 on: 11 May 2007, 12:56 pm »
Hi Frank
What Brand and model are the RCA connectors you use ?
