0 Members and 1 Guest are viewing this topic. Read 11735 times.
So really - to the point of this thread: Which do you prefer? Advantages and disadvantages of either? What do you prefer? Raw cable even?All thoughts appreciated. Peter
When it comes to either design, low mass is optimal. Speaking directly to bananas, the best I've found are the ones that Klaus uses on his Groneberg cables. These are very low mass copper with gold plating. They are a very tight fit to the binding post. If you've ever seen them up close, they are a flat sheet of copper stamped and rolled to the ID of a binding post (read=hollow and low mass).
Peter, I am one that uses no connectors...it's just another obstacle that the signal has to travel through...if you can live with it, I use the raw cables...if you are worried about, say oxidization, then tin the bare wire prior to crimping them to the speakers or amps.Tuan
I've read good reports of these gold plated copper bananas but, haven't tried them yet. The price seems fair enough... KnuKonceptz
Same goes for RCA's. Low mass rules again. Proof in the pudding is the Eichmann RCA. They are extremely low mass and have a single point of contact. They are also solid copper with no gold plated nickel over brass. Myself, I use those (again) el-cheapo tin plated copper RCA's that look like they were made in the 1950's. They sound purer to my ears than the high mass designs.The other problem is, unless you are into DIY and you know where to buy decent sounding parts, you will be hopelessly lost in upgrades constantly searching for cable nirvana.
So Scott, where do you actually get those 1950s RCAs? And that wire?
Quote from: Sonny on 22 Mar 2007, 12:11 amPeter, I am one that uses no connectors...it's just another obstacle that the signal has to travel through...if you can live with it, I use the raw cables...if you are worried about, say oxidization, then tin the bare wire prior to crimping them to the speakers or amps.TuanTrouble is ... I thought tinning them caused a sonic degradation, compared to bare copper? Regards,Andy
.... I have always wondered about the value of expensive cables if the weakest link in the electronic chain is the connection
Quote from: Gordy on 23 Mar 2007, 09:49 amI've read good reports of these gold plated copper bananas but, haven't tried them yet. The price seems fair enough... KnuKonceptzWill you be testing them soon ?
