TCG,
Have you ever listen to a fully tweaked Squeezebox in your system?
Raj
RajI have the utmost of respect for the integrity of both Wayne/Bolder and Steve/Empirical Audio - I assume you mean these two gents modded Squeezebox's. Nope, neither have been heard in my home listening zone. But, your question is rather like asking what shade of gray did I like...rather than 'did I compare an apple to an opossum'
. It's not difficult to hear a large range of CD-based setups at any show or audiophile function, it's far less frequent to hear a TT-based set-up. If you haven't exposed yourself to a bunch, you are missing out on a lot of great music....while I am likely missing out on just another shade of gray.
No matter how great the playback, and I'll assume computer based hard drives are the be-all-and-end-all in CD fidelity, you can't correct the flaws of the first 50% - the recording. The top end/treble is ragged on any CD-based playback -
for me (and I speak
only for me as everyone does hear different things in music), automatically disqualifying it as a high fidelity source. It is with considerable displeasure I find that the turntable, wrought with so many annoying traits in itself, gives a truer rendition of music. Whatever it lacks in low end extension, dynamic range, additional noise and convenience - is made up for with superior timbre & tone, and more natural midrange and, most significantly, natural (as in, like real music) treble. I am hooked listening to 75% of vinyl and perhaps 10-15% of CD.
Now, DVD-A is
very different...apparently 192,000 samples per second and Meridian Lossless Packing is mighty beneficial to augmenting already excellent resolution and signal-to-noise and dynamic range of CD....while re-creating treble sounds with far more naturalness. I'm 43, with very good cholesterol numbers, average blood pressure, am a non-smoker and always have been, the correct weight for my height and frame and I get regular chiropractic adjustments - I hear treble very acutely likely because of this all; and CD
never gets it right.
Larry/lcrimI didn't start/author this particular topic (member 'mdfoy' did) - and it's not
at all personal with me. Not in the least. In fact, it's as objective a stance as I have in audio as I've heard both many CD and vinyl-based systems. Adding tubes to CD is quite helpful to soften/rolloff the ragged high's and using single driver speakers creates a natural high frequency filter - eliminating the most objectionable part of CD performance before it can irritate much - whatever your playback source
I'm not knocking either (I use lots of tubes myself as you know); you're certainly entitled to spend your audio dollars any way in which you desire without rancor.
I know I expose myself to much heated response for my views, which appear to be very fixated, but they are in fact not. I am a remarkably pliable/flexible individual - I am just very pragmatic about certain subjects and it raises certain emotions in many. Forgive me for doing so, it is not my intent - my views are no doubt a small slice of the music loving public, yet they are mine to share
You must at least admit, I express them creatively and with flair, at least - even if you don't agree with them.
