0 Members and 1 Guest are viewing this topic. Read 5649 times.
Would you consider a plasma or DLP?What is your room like in terms of light?How far do you sit from the tv?Without knowing the answers to these questions, it is hard to recommend something.George
I am very partial to the Panasonic plasma tv's. Great picture at a very good price.You could get a 50" at the edge of your price range.George
If you are a Costco member buy your new TV there. You can keep it for years and if you have all the packaging they'll take it back and give you a 100% refund. That's for real!!! I seen it done and not only with TV's but just about everything they sell. Cheers Charlie
Like George said the Panny plasma is hard to beat.Check out Visual Apex. They are a great online dealer. I bought my Panny plasma from them. They are an AVS Forum sponsor.They have the 50" Panny plasma on sale for $1875 (+ shipping) including a five year warranty.Check it out @ the link below:http://www.visualapex.com/plasma/Plasma_details.asp?chPartNumber=TH-50PH9UK&MFR=Panasonic
The overall best picture, currently comes from the dlp rear proj (SONY 60" 1080P SXRD)
QuoteThe overall best picture, currently comes from the dlp rear proj (SONY 60" 1080P SXRD) The Sony isn't a DLP, it uses SXRD, Sony's implementation of LCoS (Liquid Crystal on Silicon). DLP, as the commercials say, produces its picture with a chip consisting of tiny mirrors that pivot to reflect light, creating a gray scale image. One major difference between current DLP rear projectors (as well as most front projectors) is that they are one-chip models, meaning that the color is produced by means of a spinning color wheel. The Sony SXRD (as well as the JVC HD-ILA -- also an LCoS design -- and LCD tvs) use three chips, one each for the red, green and blue, meaning that they don't need a color wheel to produce the color. Why is that important? Because one artifact that can potentially pop up with a one-chip DLP display is the so-called rainbow effect. Not everybody sees rainbows. I for one never saw one for the longest time. But once I saw one, I saw many. Sort of like those optical illusion pictures. Once you see the picture the first time, you can't help but see it more. Whether rainbows are a problem for a person is up to the individual. For me they would be annoying. Which is not to say that LCoS or LCD are inherently better. All of these sets have their own quirks. DLP, for instance, generally can produce a truer black level than LCD or LCoS, and can therefore produce better contrast in scenes that have both dark and bright together. I have a JVC HD-ILA, and as much as I like it, the fact is that it just can't make a deep black. Newer sets are supposedly better, but I don't think any of them can come close to the good ol' CRT.There are going to be drawbacks to any display. It can be daunting, but AVS Forum has lots of good information that might help you identify the particular limitations of the various types of displays so that you can pick the one that has the least amount of compromises for your particular situation.Of course, keep in mind that many (most?) people will be thrilled with the picture from any new set. I guess it depends upon how picky you are. The people that frequent AVS tend to be pretty obsessive.Whatever you get, Zybar's recommendation for a professional calibration is a good one. I'm finally in a position where I can have a pro tweak my set, and I'm looking forward to the improvement.
